Hello Guest it is November 13, 2026, 11:28:03 AM
Author Topic: Toolpath display smaller than my work piece.  (Read 12559 times)
« on: January 02, 2019, 03:41:54 AM »
Hi peoples,
I recently tried running a program and the gcode loaded perfectly but the toolpath display only shows a tiny portion of it and once it reaches that point it just stops dead in the middle of my workpiece. My table coordinates are correct and I’ve tried hitting the “regen toolpath button “ but nothing happens. Anyone know what I’m doing wrong? TIA
  •  9,377 9,377
Re: Toolpath display smaller than my work piece.
« Reply #1 on: January 02, 2019, 04:36:50 AM »
You are perhaps in Demo mode which only runs 500 lines of Gcode. Install your license file and all will be well  ;)
« Reply #2 on: January 02, 2019, 05:25:48 AM »
Thanks for the reply, I’ve done larger projects in the past and it’s never been a problem. Is there perhaps a way of increasing the tool path ?
  •  9,377 9,377
« Reply #3 on: January 02, 2019, 05:50:11 AM »
Does your graphics card have sufficient ram ?
« Reply #4 on: January 02, 2019, 06:15:23 AM »
Yes. Ive tried reinstalling the licence but it still doesn’t seem to want to go past the 500 lines of code. I really don’t know what else I can do :/
  •  9,377 9,377
« Reply #5 on: January 02, 2019, 07:30:35 AM »
When you click Help : About Mach3,  does the Licensed To... box show your name ?
« Reply #6 on: January 02, 2019, 07:45:50 AM »
Yes :)
Offline Stuart
  •  311 311
« Reply #7 on: January 02, 2019, 09:35:38 AM »
Tweakie
Just a thought from a old git
There are two resent posts with the same problem long running installs that have suddenly reverted to demo mode and both posters have stated they are licensed correctly with there own name in the info field
Could this be linked to a recent windoze update
It does seeem a bit odd to me
For the record I do not use mach3 although I do have a lic. I used mach4 hobby at this time maybe a up grad to the industrial ver in the future as I do a bit of paid work
So take my comments as is I have no means of proving my theory just taking a step back and looking at the wider picture
Stuart
  •  9,377 9,377
« Reply #8 on: January 03, 2019, 12:51:34 AM »
Hi Stuart,
I suppose it is possible that a Win update could be to blame.
I use WinXP and am immune to updates, I think I would suspect a corrupt .xml and do a complete re-install of Mach3 to see if the problem persists but, as you say, it is a strange one.
