Hello Guest it is October 30, 2026, 04:26:46 PM
Author Topic: Help with table coordinates.  (Read 46913 times)
« on: December 29, 2018, 11:41:01 AM »
Hello, I am building a 6ft x 11ft plasma water table. Table is mostly completed. Using Masso controller. I am very new at this and learning from scratch. I have the homing set at Z0,X0,Y0. Everything goes to the back left corner. From there my coordinates goes X 0-120", Y 0-64", Z all the way up, 0-4" Is this right? Or do I need to splite the distance and have  Orgin in the center with negative at on end? Meaning my home would look something look X -60 Y -32, Z 2.
I uploaded a picture. Any help be appreciated.
Offline TPS
  •  2,627 2,627
Re: Help with table coordinates.
« Reply #1 on: December 30, 2018, 03:52:16 AM »
not realy, normal it you are in front of your table:
x to the right is positive
y forward is positive
z up is positive
have a look (describes the right Hand rule):
http://forum.machsupport.com/forum/index.php/topic,10308.0.html
« Reply #2 on: December 30, 2018, 06:00:34 AM »
Hmm, so you saying I have X and Y backwards?
Offline TPS
  •  2,627 2,627
« Reply #3 on: December 30, 2018, 06:03:19 AM »
if the left side off your Picture is the front side of your machine,
then y is backward, and z as well.
« Last Edit: December 30, 2018, 06:11:51 AM by TPS »
« Reply #4 on: December 30, 2018, 06:11:21 AM »
My front is at the end.
Offline TPS
  •  2,627 2,627
« Reply #5 on: December 30, 2018, 06:14:25 AM »
that is not "normal",
because all drawings have this orientation
 Y+
 |-----X+
so you allways have to "rotate" in your head.
« Reply #6 on: December 30, 2018, 06:23:44 AM »
So, I do have my X axis and Y axis backwards?
Offline ZASto
  •  434 434
« Reply #7 on: December 30, 2018, 07:22:25 AM »
Yur Home position should be towards your bottom-left.Looking at your photo/drawing Your Y should be X, and your X should be Y
My personality is who I am.
« Reply #8 on: December 30, 2018, 07:26:27 AM »
Yes, it's backwards, but you don't have to change it.
If you set your Y home to be 64, then it's fine like that. Just set the Y Home Offset to 64, and Y 0 will be at the other side. And moving in the correct direction.
« Reply #9 on: December 30, 2018, 07:57:13 AM »
Thank you very much. That explains the issues I been having in Sheetcam. I will change it, it will drive me nuts every time I look at it. Thanks again for everyone who took time to help me out.
