Hello Guest it is October 09, 2026, 03:51:11 PM
Author Topic: Define own global Variables to use in macros  (Read 5984 times)
« on: December 25, 2018, 03:09:47 AM »
In the "screen load script" I would like to define my own global variables and functions that are also available in macro scripts (m6).
I tried it with the following variables
myOwnVariable = 1;
mc.myOwnVariable = 1;
but in m6 script these are not available. when calling the scripts is executed up to this point and then the script aborted. I do not see any error message like "m6, line55: attempt to compare nil with string". Is there a log file in which such errors are written?
Re: Define own global Variables to use in macros
« Reply #1 on: December 25, 2018, 05:27:23 AM »
the screen load script is in the GUI 'chunk' whereas the m6 macro is in the Gcode interpreter 'chunk'.
A variable in one chunk is not available in the other.
There is a way to pass data between chunks......use registers. In the Docs folder:
Mach4 CNC Controller
Lua Scripting Guide
Section 4 from page 14.
