Hello Guest it is October 24, 2026, 04:33:51 PM
Poll
feed rate, oem button
feed rate
0 (0%)
oem button
0 (0%)
Total Members Voted: 0
Author Topic: Mach 4  (Read 6339 times)
Mach 4
« on: December 23, 2018, 06:13:31 AM »
Hello
I have just installed Mach 4 with the IP-M controller.
And now I have 2 questions
1. I have installed a potentiometer for the feed, when I turn it also changes the feed rate on the screen but not the jog, you can change that.
2. I can not find any settings for OEM switches eg. Start-Stop break.
greeting
Torsten
Re: Mach 4
« Reply #1 on: December 23, 2018, 12:49:08 PM »
1) Yes you can do this, note that typically the jog rate and the feed rate are separate. If you wish to link them you can use this API:
LUA Syntax:
rc = mc.mcJogSetRate(
      number mInst,
      number axisId,
      number percent)
Description:
Set the jog rate of the given axis as a percentage of the axis' maximum velocity.
You could write a small script in the PLC script which would then continuously cause the jog rate to be the same or some fixed percentage of the feed rate.
OEMs are a Mach3 term and do not occur in Mach4 at all. You need to read the manual:
Mach4 CNC Controller
Lua Scripting Guide
found in the Docs folder of your Mach4Hobby directory, particularly section 5.1 page 18. You will find that Mach4 signals
are handled in a different manner to Mach3, in particular they are not polled as in Mach3 and consequently lend themselves to treatment
in a Signal Library Table. Understanding how the Signal Library Table works is a major breakthrough in your understanding of Mach4
and a perfect example of the 'function as a first class value' programming paradigm that is offered by Lua. A simple concept.....but Oh so
valuable!
Thereafter you will find input signal (ISIG_INPUT*********) and output signals (OSIG_OUTPUT*********) listed in the API.chm in the docs folder.
I have attached aof list, I find it useful enough I have put it in the Docs folder as well. There are hundreds of signals defined.
Re: Mach 4
« Reply #2 on: December 23, 2018, 04:47:48 PM »
thank you
