Hello Guest it is October 24, 2026, 07:10:12 PM
Author Topic: Excel to Mach4  (Read 7150 times)
Excel to Mach4
« on: December 13, 2018, 01:55:13 AM »
Hi Guys,im very new to mach4 and i would like to check if there is any way to export data from an excel file to mach4?
Thanks!
« Last Edit: December 13, 2018, 01:57:29 AM by Ryan.S »
Offline thosj
  •  542 542
Re: Excel to Mach4
« Reply #1 on: December 13, 2018, 07:08:14 AM »
I'm guessing yes here. We did this back in the day, before fancy CAD/CAM, to mill cam tracks. Let Excel calculate the path and output the text file. Gcode is nothing more than text, so anything that saves a text file will import to Mach4 gcode. If you can write Gcode in Notepad, you can surely do it in Excel!! The trick, of course, is getting the output format correct.
Tom
Tom
Re: Excel to Mach4
« Reply #2 on: December 13, 2018, 07:04:53 PM »
Ok got it! Will give it a go and let you know again.Thanks !
Re: Excel to Mach4
« Reply #3 on: December 03, 2021, 08:48:34 AM »
Hi Ryan, I'm not sure how you got on with this but you might be interested in this post I made yesterday.
https://www.machsupport.com/forum/index.php?topic=45560.msg289783#msg289783
