Hello Guest it is November 22, 2026, 02:27:23 PM
Author Topic: Prefix in edgecam  (Read 11729 times)
Prefix in edgecam
« on: August 06, 2007, 02:36:25 PM »
Hi. I have converted to ISO-code some pictures from Edgecam and Mach3 did open those quite well. I'm using some fanuc "machines prefix" (in Edgecam this is called Machine Sequence Tool) what I found in Edgecam directory. File extension for the prefix file what I mean is .MCP
What prefix for mach3 you guys use?
Is there some custom prefix-file for Mach3?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Prefix in edgecam
« Reply #1 on: August 06, 2007, 03:37:53 PM »
Mach3 uses .TAP extensions.
Graham.
« Reply #2 on: August 07, 2007, 04:00:57 AM »
Yes, but I'm looking the Machine Sequence -file for Edgecam. So do someone got that file, or should I use some file for fanuc-control, some is really close to Mach3?
Is some fanuc-control working exactly same, like Mach3?
  •  2,785 2,785
« Reply #3 on: August 07, 2007, 03:53:51 PM »
Use a Fanuc 6 post, it is very close to mach3.
Graham.
