Hello
Guest
it is
November 02, 2026, 08:08:29 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach3 under Vista
Changing stepper motors with more amp draw
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Changing stepper motors with more amp draw (Read 22629 times)
expressjoe
4
on:
December 10, 2018, 12:58:06 PM »
Hi all,
Very green to all of this, so bear with me...
We replaced our green 3 amp stepper motors on the X axis with 5 amp stepper motors. Once running the machine started tapering X axis cuts. We are going to change all 4 motors on the table to the black 5 amp motors. Is there anything we need to change in Mach 3 to make for a smooth transition? Both motors have 200 steps per rev. Running Windows 7 Ultimate.
Any help on this would be appreciated.
thanks in advance.
_
Logged
Re: Changing stepper motors with more amp draw
Reply #1 on:
December 11, 2018, 09:39:15 AM »
The steps per unit should be the same but I would still check the calibration after retuning the motors for max velocity and accel values.
Suggest you have a look at stepper info provided on the Geckodrive site. Your drives should be capable of the amp requirements.
Logged
expressjoe
4
Reply #2 on:
December 11, 2018, 09:57:36 AM »
Right on , will do , huge thanks Rich
Logged
ger21
6,295
Reply #3 on:
December 11, 2018, 10:37:37 AM »
If all you changed is the motors, then the new motors may actually have less torque at higher speeds, causing loss of position.
Do you have new drives, or are you setting the old drives to provide 5 amps to the motors?
Logged
expressjoe
4
Reply #4 on:
December 12, 2018, 10:56:33 AM »
I am using the old drives ( control boards?) for the new motors. they worked great for two weeks then started acting up.
Logged
joeaverage
7,663
Reply #5 on:
December 12, 2018, 11:36:00 AM »
when a stepper motor de-accelerates (in fact any motor) it becomes a generator and pushes power back into the stepper drive, the amount of energy pushed
back into the drive is equal to the kinetic energy of the rotor and moving load.
Some drives handle the regeneration phase better than others....it sounds like your original drives were a bit weak.
Gecko's have the best reputation among CNC'ers but Leadshine AM822's also have a good reputation at about 1/2 -2/3 the price of a Gecko.
Logged
expressjoe
4
Reply #6 on:
December 12, 2018, 01:29:06 PM »
Thanks Craig. I got all 4 new motors working now, cables, motors and controllers working as normal , now test cuts.
Logged
Print
Pages:
1
Go Up
« previous
next »
