Hello Guest it is September 16, 2026, 05:16:41 AM
Author Topic: Z 0 being reset in G-Code  (Read 8329 times)
Offline CES
  •  62 62
« on: December 06, 2018, 12:30:28 PM »
I have started noticing that when I run my G-Code, the first Z action is to move Z up. Then Z zero is SET to 0, not to G54 Z zero. I end up cutting air.
I'm on a Grizzly G8689 CNC running Mach3.
I made one part with the attached code then this issue started.
Reload Mach3?
I think others have posted this but Search is not working so I can't find the threads.
Need help.
CES
Offline CES
  •  62 62
Re: Z 0 being reset in G-Code
« Reply #1 on: December 08, 2018, 12:06:15 PM »
I am not making the change to Z 0, it is occurring in G-code or Mach3.
« Reply #2 on: December 08, 2018, 01:26:43 PM »
Maybe the G43 tool length offset?
Offline CES
  •  62 62
« Reply #3 on: December 10, 2018, 03:43:13 PM »
ger21 or Gerry,
  That was it. I removed the G43 from the file and it is now cutting. I checked the .pst file and it has been on from day 1 so I wonder why it started taking effect.
To remove this from future nc files, do I change the quoted G43 with double quotes? ""
Thanks Gerry,
CES
