Hello Guest it is October 20, 2026, 06:02:58 PM
Author Topic: Plasma cut parts not matching drawing sizes.  (Read 6650 times)
« on: December 05, 2018, 11:10:35 AM »
Hello everyone. I am having an issue with the my parts being cut at a different size than the drawings. First off I have drawn the identical part in both turbo cad and inkscape. When I load part into sheetcam and use the measure tool the part does not match the drawn size it is smaller. So my first guess is a sheetcam problem. Anyway if I continue to cut part in Mach 3 version 67 using an inside offset with correct kerf offset it is not correct. I have calibrated all axis in mach and did not have to change any settings therefore they were correct all axis move to exactly the correct position. Anyone else having this issue and possible solutions. Thanks
