Hello Guest it is October 05, 2026, 08:01:03 AM
Author Topic: No Motor movements  (Read 7675 times)
No Motor movements
« on: December 04, 2018, 04:05:27 PM »
Hi People. Just built a homebrew CNC machine with plans from Hobby CNC.
     Installed Mach 3, The program seems to like my computer ran the Driver test program, setup all the correct parameters I think according to the website for their controller, all the wiring checks out.
Problem I have is the X axis motor only turns one way,  it sounds good, Y & Z axis do not move at all, though Z axis motor make a noise but does not turn.
Any help appreciated Thanks David.
Re: No Motor movements
« Reply #1 on: December 19, 2018, 02:53:56 PM »
Good Day David.
I the same as you have just finished my CNC Milling machine, (i Have built it from a old bridgeport),  and have the same problem as yours, Where my X axis only turn in one direction and Y & Z axis dose not move. Did you manage to find you problem? If not dose any one have an answer to help us.
Thank you
Branden
« Reply #2 on: December 19, 2018, 03:42:14 PM »
Hi Branden
Yes. I have finally have my unit working, believe it or not I was reading my Multimeter wrong, trying to run it on to low a voltage.
I now have torque, and good movement.
Thanks David :D
