Hello Guest it is November 01, 2026, 10:03:53 AM
Author Topic: pocketing problem  (Read 28299 times)
pocketing problem
« on: December 04, 2018, 10:25:14 AM »
I am using the laser post. When i engrave lines it works fine. When i use the pocketing function it adds a bunch of concentric circles to the toolpath when i load it to Mach. In the lazycam screen everything looks correct.
  •  9,375 9,375
Re: pocketing problem
« Reply #1 on: December 05, 2018, 12:48:02 AM »
In Config / General Config.   change the IJ Mode.
Ideally, all Gcode files containing arcs should specify the G90.1 or G91.1 (as appropriate).
« Reply #2 on: December 05, 2018, 04:10:40 PM »
That was it.
Gene
