Hello Guest it is October 21, 2026, 03:10:01 AM
Author Topic: Zinhibit / multipass disappeared  (Read 8253 times)
« on: December 01, 2018, 12:27:35 PM »
I've been using Mach3 for some time now.  One of the very useful things the Zinhibit / multipass feature (located in the lower right of the attached picture).
I installed on another computer, and this has disappeared.  I don't know if it's because it's a later version (I can't imagine someone wanting to eliminate this  feature) or if I somehow added it and don't remember how.
Anyone know how to get this back?
Re: Zinhibit / multipass disappeared
« Reply #1 on: December 01, 2018, 05:53:48 PM »
Going by memory, I believe this feature was removed and replaced by a multipass wizard in newer versions.
This happened about 8 years ago, maybe longer?
« Reply #2 on: December 01, 2018, 07:22:31 PM »
Gerry,
OK, thank you.  That computer was a workhorse, everything worked well, so I never bothered to update Mach3 (the adage "don't fix it if it's not broken!").
That was a very nice feature - easy to turn on and off quickly and make changes.  The wizard isn't as convenient.  Now I need to decide whether to simply go back to an older version.
Thank you for letting me know.
Jerry
