Hello Guest it is October 21, 2026, 07:57:30 AM
Author Topic: Problem while setting Homing Offset in Mach3  (Read 10670 times)
« on: November 25, 2018, 08:33:16 AM »
Hi everybody,
I set up my CNC machine with Mach3 and almost everything works just fine, but I can't figure out how to offset the homing endstop zero.
Right now the homing system works fine except for the fact that I would like to have the Y machine coord set to 600 when endstop is reached, during axis referencing, instead of 0.
I already tried to set the "Home Off." to 600 (in Config -> Homing/Limits), but this doesen't seem to have an effect at all.
I don't know if I'm doing something wrong or if it's kind of a bug in Mach3.
Thanks in advance
Re: Problem while setting Homing Offset in Mach3
« Reply #1 on: November 25, 2018, 09:04:42 AM »
If you are using a motion controller, rather than a parallel port, it could be that your controller does not support the Home Offset option.
« Reply #2 on: November 25, 2018, 04:20:44 PM »
Yes, I'm using an ethernet controller.
Is there any way to fix it? Maybe with a macro, or by editing the script for the ref button? Can a macro directly modify machine coords?
« Reply #3 on: November 25, 2018, 04:48:34 PM »
What controller? What make? What model?
As Gerry points out homing offset is done by the controller....I don't think there is a way to overwrite the machine coordinates.
« Reply #4 on: November 25, 2018, 04:54:43 PM »
Novusun NVEM 5 axis
« Reply #5 on: November 25, 2018, 06:23:19 PM »
Buy a controller that supports all of Mach3's functions. Most if not all Chinese boards do not.
« Reply #6 on: November 27, 2018, 12:10:45 PM »
In the OEM DROs list there is a group called Coordinates Machine ABS (from 83 to 88), but apparently using a SetDRO or a SetOEMDRO on one of theese doesn't do anything.
Could they be in a sort of read-only mode?
