Hello Guest it is October 22, 2026, 10:49:13 PM
Author Topic: Does Mach4 have a "skip optional block" function?  (Read 5581 times)
« on: November 19, 2018, 12:40:18 AM »
For example, on a Haas machine, if a block of gcode has a "/" before each line, all of those lines are optional and can be skipped by the operator.
The closest functionality I have found is to insert a M00 or M01 before the block I want to be optional, with a comment that tells the operator to manually skip to the next op if desired.  But that's a little cumbersome.
Re: Does Mach4 have a "skip optional block" function?
« Reply #1 on: November 19, 2018, 12:45:15 AM »
Nevermind, I see that it does.  Now its just a matter of getting my CAM post processor to put "/" on the lines I want.
