Hello Guest it is October 23, 2026, 01:01:39 AM
Author Topic: Mach4 Restrictions when unlicensed  (Read 6355 times)
« on: November 18, 2018, 07:56:47 AM »
Hi all, newbie to Mach4 here.
I'm just experimenting with CNC at the moment, and have an IP Smoothstepper connected to Mach4, I haven't brought a licence yet as I'm still in the 'messing about' phase. I'm aware of the runtime restriction.
I have the Smooth Stepper hooked up to 4 motor drivers via port 1; each seems to work fine, but only if mapped to Motor-0 in Mach, so just changing the mappings in Mach allow me to move an axis.
So my question is, is Mach4 limited to driving only a single motor while unlicensed, or have I messed up something else?
Stephen.
Re: Mach4 Restrictions when unlicensed
« Reply #1 on: November 18, 2018, 08:03:28 AM »
Demo mode does not restrict you to only one motor. It it highly
unlikely that you have a hardware failure that causes this type
of symptom. Look carefully at your Axis mapping and motor
configurations.
Steve Stallings
www.PMDX.com
« Reply #2 on: November 18, 2018, 08:08:01 AM »
Thanks, I went back and checked the settings and found I had mapped the output pins in ESS, but not enabled them! Opps!  Works like a charm now.
Cheers,
Stephen.
