Hello Guest it is October 21, 2026, 04:03:59 AM
Author Topic: missing motor tuning screen mach3  (Read 10843 times)
« on: November 12, 2018, 10:32:05 AM »
when i try to open the motor tuning screen under config setting it is not there
how do i get it back so i can tune the motors, it was there now it is not where did
it go
also how do i search for something all i get is an error message about not able to find en in language settings
  •  9,374 9,374
Re: missing motor tuning screen mach3
« Reply #1 on: November 13, 2018, 12:44:51 AM »
Hi Jim,
Sounds like you do not have any drivers installed.
If you are using the LPT Parallel Port then run DriverTest.exe (Mach3 folder) this will install the missing drivers.
This forum is currently undergoing a re-think on layout, content, etc.  http://www.machsupport.com/forum/index.php/topic,38649.0.html
Some functions (such as search and link re-directs, etc.) may be a little cranky until it is all sorted  :'(
« Last Edit: January 09, 2019, 02:05:14 AM by Tweakie.CNC »
« Reply #2 on: November 23, 2018, 04:26:39 PM »
I'm having the same problem, no motor tuning screen. i'm using the UC100 USB adapter. Will the drivers reset work for me also. It has been running OK, just wanted to set the steps per unit and my Y axis wont work. Thought I would reset motor tuning but no screen. any help would be greatly appreciated.
« Reply #3 on: November 24, 2018, 09:08:06 AM »
Do you have  the plugin for that adapter currently enabled in Mach 3?
« Reply #4 on: November 25, 2018, 05:57:13 PM »
 I down loaded the UC100 down load and enabled it. It works fine on my laptop with Windows 8. Im trying to use it on my new computer with Windows 10. It had been working but i needed to reset my steps per units, thats when I had problems with the X axis. So i figured i needed to retune the motors and thats when i noticed the window wont open. all other windows open OK.
« Reply #5 on: November 25, 2018, 06:53:51 PM »
Can't help you on the Win 10  as I am not there yet.  ;)
