Hello Guest it is November 13, 2026, 09:35:28 AM
Author Topic: LIMIT I/O how ?  (Read 15940 times)
Offline cnc-project
  •  9 9
  • moja mala beba
    • www.cnc-project.com
LIMIT I/O how ?
« on: March 27, 2006, 02:22:39 AM »
Im controled before on turboCNC , and now can problem how diseble  drives (pin 16) and configure LIMIT SWITCH   ...8 END LIMIT on axis, and 8 for manual like offset on stock  etc...
can some explain me  how can do  that ?
have 5VDC  (LM7805) optocooupler 16 ch, and 12VDC for relay ...
potencial of ZERO not problem, only  port-pin configuration...
is P3 933 Mhz , enuagh for MACH 3 on 25kHz ?
« Last Edit: March 27, 2006, 02:40:19 AM by cnc-project »
Re: LIMIT I/O how ?
« Reply #1 on: March 27, 2006, 05:59:24 AM »
Ther are outputs called Enable1-6. The output of this is to turn on and off your Drives. Have you had a look at the video's on how to test up mach? There is a good one on setting up the limit switches.
www.newfangledsolutions.com
www.machsupport.com
