Hello Guest it is October 24, 2026, 01:40:09 PM
Author Topic: Lag on inputs  (Read 20357 times)
Lag on inputs
« on: November 07, 2018, 02:43:56 PM »
Hello
Short code:
Code: [Select]
SetOutBit(90, 2)
    CamRdy = false
    While(Not CamRdy)
        If(GetInBit(90, 10)) Then
        ResetOutBit(90, 2)
            CamRdy = true
        End If
    Wend
Oscilloscope hooked up to input nr 10 and output nr 2. There is a lag of about 100ms!
If I use code:
Code: [Select]
SetOutBit(90, 2)
Sleep(100)
ResetOutBit(90, 2)
Sleep(100)
SetOutBit(90, 2)
Sleep(100)
ResetOutBit(90, 2)
Then the impulse width on the output is 102-103ms.
So nothing wrong here, looks like there is lag on the inputs.
Offline TPS
  •  2,627 2,627
Re: Lag on inputs
« Reply #1 on: November 08, 2018, 02:02:38 AM »
contact CSLAB via:  office@cs-lab.eu
and ask Wojtek Trawicki for Support.
Re: Lag on inputs
« Reply #2 on: November 08, 2018, 02:25:54 AM »
That was the first thing I did :-)
Re: Lag on inputs
« Reply #3 on: November 09, 2018, 04:45:19 PM »
Today I got an answer: "We tested it on our setup and average lag time was 90ms, we advise to use PLC in this case".
Re: Lag on inputs
« Reply #4 on: November 09, 2018, 04:53:12 PM »
Two-three hours later something came to my mind:
It's weird, when I run one of the axis against a limit switch, the reaction time is usually below 10ms.
When I run the tool length macro it's the same.
Why on earth here is 90-100ms?
Tomorrow I'll define those inputs and outputs from Csmio in the MACH3, then declare them in my test macro and see what happens.
Re: Lag on inputs
« Reply #5 on: November 11, 2018, 02:37:53 PM »
I did this test and came with the same unacceptable delay.
So I can't make my tool changer to work correctly.
Offline TPS
  •  2,627 2,627
Re: Lag on inputs
« Reply #6 on: November 15, 2018, 01:25:36 AM »
hello,
you can try to add two additional relays for a "Hardware Stop"
according to attached drawing
Rel1 -> Motor turn relay
Rel2 -> enable stop relay
Rel3 -> stop relay paralell to CSMIO Input
Software sequence would be:
1- turn Rel1 on to turn turret
2- if turret Position reached turn Rel2 on to enable HW Stop
3- if Input is ON turn OFF Rel1 + Rel2
with this small circuit you will get the fastest stop time, because the Rel3 will turn OFF the motor
