Hello Guest it is November 02, 2026, 09:16:51 AM
Author Topic: Mach3 usb port&pin setup  (Read 33785 times)
« on: November 07, 2018, 02:00:43 PM »
Hi, I just got my 6030 CNC and am running mach3 through a laptop with USB port connection. In searching the forums, I don't see any mach3 Config setup for the USB 6030.
Thanks for any help yall can give.
Re: Mach3 usb port&pin setup
« Reply #1 on: November 07, 2018, 11:52:01 PM »
USB 6030.
is not a make and model.
You need to post some details about the controller. Chances are that being Chinese that you will find zip about them.
« Reply #2 on: November 08, 2018, 05:39:39 AM »
Thank you for your reply.
It is chinese cnc, comes with USB Interface Controller Card.
Offline ZASto
  •  434 434
« Reply #3 on: November 08, 2018, 06:59:21 AM »
First of all, contact your seller to provide you the support for hardware that you bought. When it comes to Mach people on the forum will try to help you.
This forum is NOT for providing tech support for chinese machines.
Your controller should have a name. You should be supplied with plugin for the board as well as the manual how to set it up.
My personality is who I am.
  •  9,375 9,375
« Reply #4 on: November 08, 2018, 07:02:10 AM »
ZASto is absolutely correct, your supplier should provide all the support you should need.
However, perhaps you could post a few pictures of your machine and controller including the inside of the controller box - this may help others identify your Chinese stuff.
« Reply #5 on: November 08, 2018, 07:43:33 AM »
There are about 50 different chinese controllers. Which one do you have?
