Hello Guest it is October 20, 2026, 07:46:25 PM
Author Topic: CNC Router VFD spindle help.  (Read 19611 times)
« on: November 07, 2018, 06:17:26 AM »
I am using Mach 3 with a Benchtop Pro CNC Router. I am wondering if there is any way I can have Mach 3 execute following commands while spooling up the spindle to 22000RPM. I am loosing 8 seconds in cycle time since the program waits for the spindle to get up to 22k RPM before it moves to next line. Any help is much appreciated!
Re: CNC Router VFD spindle help.
« Reply #1 on: November 07, 2018, 06:19:25 AM »
« Reply #2 on: November 07, 2018, 07:06:17 AM »
Config >Ports and Pins > Spindle tab. There are settings for delays there.
« Reply #3 on: November 07, 2018, 04:01:46 PM »
I am new to Mach 3 so would you mind explaining in detail?
« Reply #4 on: November 07, 2018, 05:50:21 PM »
What are your settings on this screen?
« Reply #5 on: November 13, 2018, 07:01:42 AM »
Thank you so much! My Spindle delay was set to 5 seconds from the factory. Is it safe to set it to 0s delay or 1s is a standard?
« Reply #6 on: November 13, 2018, 10:37:53 AM »
That depends on how fast your spindle gets up to speed.
