Hello Guest it is November 18, 2026, 12:34:24 PM
Author Topic: Assign input to the controller, CICLE START button  (Read 9992 times)
« on: November 07, 2018, 12:57:22 AM »
Hello to the whole forum.
I'm italian, I use google translate.
I would like to assign an external key to the SINGLE BLOCK function, then an Input for the controller.
how can I do?
I own CSMIO-IP / S
thank you.
Re: Assign input to the controller, CICLE START button
« Reply #1 on: November 07, 2018, 07:41:12 AM »
daniba73,
Once you map a button to an input in Mach4 then you  can put this script into the signal library in the screen load script.
I have this example mapped to input 5
[mc.ISIG_INPUT1] = function (state)
     if (state == 1) then --
   --Single Block Toggle Test
   local SBMode = mc.mcCntlGetSingleBlock(inst)
   if SBMode == 1 then
      mc.mcCntlSetSingleBlock(inst, 0)
    else
      mc.mcCntlSetSingleBlock(inst, 1)
    end
    end
end,
Chad Byrd
« Reply #2 on: November 07, 2018, 04:09:56 PM »
Yes, it works
part immediately active.
can you do it reverse?
« Last Edit: November 07, 2018, 04:18:49 PM by daniba73 »
« Reply #3 on: November 07, 2018, 06:33:32 PM »
Daniba73,
It toggles correctly?
You can reverse the logic, yes.
   if SBMode == 0 then
    else
    end
    end
end,
« Last Edit: November 07, 2018, 06:35:31 PM by Cbyrdtopper »
Chad Byrd
« Reply #4 on: November 08, 2018, 04:54:56 AM »
toggles correctly.
thanks you have been very kind!!
« Last Edit: November 08, 2018, 04:59:13 AM by daniba73 »
« Reply #5 on: November 08, 2018, 03:00:21 PM »
So it works like you want now?
Chad Byrd
« Reply #6 on: November 09, 2018, 12:35:15 AM »
Yes,Yes!
Very good!
thank you again!
P.S. I would like to add some sounds to Mach4, but I open a dedicated topic.
« Reply #7 on: November 09, 2018, 03:07:49 AM »
Note:
with the second code, it did not work for me.
I'm using the first one.
Mach4 boot active part, but it is not a problem.
