Hello Guest it is November 21, 2026, 03:48:20 PM
Author Topic: Mach4 Shuts down when loading any g-code file.  (Read 7410 times)
« on: November 06, 2018, 09:41:14 PM »
I need some help, I installed mach 4 on an older xp PC. It installed fine, and starts. as soon as I try to load ANY g-code file it immediately force closes. I use the exact same setup on two other machines without trouble. I have tried everything I can think of. Clean install, service pack 3, latest MACH4, etc. It fails on mill and lathe profiles, mine and oem. The lathe functions, moves, can jog , etc...  Thank you very much
Offline smurph
  •  1,575 1,575
Re: Mach4 Shuts down when loading any g-code file.
« Reply #1 on: November 11, 2018, 01:05:28 AM »
Try updating your video driver.
Steve
« Reply #2 on: November 13, 2018, 08:41:40 AM »
I gave up.  Not enough ram on video card.  Using new machine instead.
