Hello Guest it is October 10, 2026, 10:57:47 AM
Author Topic: Mill setup config for Y axis movement type  (Read 35765 times)
« on: November 06, 2018, 08:58:56 AM »
There is a fundamental difference between having a moving tool for Y axis travel, or moving the work piece past the tool.
Having a moving work piece changes the orientation of the tool path display so everything is backwards compared to the default configuration.
Can there be a selection for tool travel vs work piece travel?
On my machine the Y axis is set up for Y+ moves the work to the front of the machine, Y- moves the work to the back.
Re: Mill setup config for Y axis movement type
« Reply #1 on: December 05, 2018, 06:03:48 AM »
Always think in terms of the tool moving regardless of what actually moves.
Then set up the machine motions so that the display matches.
It is just a matter of selecting the correct directions in axis movement and homing.
Mike
« Reply #2 on: December 05, 2018, 03:34:44 PM »
That sounds terrifically obvious, but I see that in reality that's not what I've been doing. Because the work moves for Y axis, I think in terms of moving the work when I write the G code. I will try to change my thinking along these lines and see if it makes it easier.
I have the axis directions reconciled with the display, and arcs and circles move in the correct direction, so it's just me that needs adjustment.
« Reply #3 on: December 05, 2018, 04:02:45 PM »
A few adult beverages can make the adjustment go a lot smoother!
Have fun with the machine.
WARNING
Never drink and drive your machine.
Mike
« Reply #4 on: December 05, 2018, 05:59:39 PM »
I can't even contemplate having a few doses of vitamin R and being in the same room as that machine.
I have, in the past, actually made errors while under the influence. And I learned from that.
If I can prune a finger nail with the mill while cold sober, I'd take off a couple fingers after drinking anything.
I will share this in case it helps someone.  I just got a new milling vise and promptly peeled back an inch of skin on a finger by bumping into a raw edge of the thing.
Freshly milled edges are sharp ridiculously sharp.
