Hello Guest it is November 22, 2026, 06:47:11 AM
Author Topic: XHC V5.10 usb controller not working under XP  (Read 5199 times)
« on: November 06, 2018, 02:35:24 AM »
Hi
I have XHC V5.10 usb controller and would like it to work under XP I have mach4 working ok but if I copy the plugin for this card to the plug in directory of mach4   Mach4 locks up and gives this message attached and also a dump file
I tried on a windows 10 computer and it works fine I have a MPG and the plugin for that works under XP and mach4 with no problems
any ideas
I really want to use this computer as it is a old small form factor type  and fits a spot on the machine perfectly and I do not think it will run   on win 10 as it is to old
Regards Ray
