Hello Guest it is November 22, 2026, 06:53:40 AM
Author Topic: XP PRO SP3 Mach4 will not RUN  (Read 6521 times)
« on: November 05, 2018, 06:00:05 PM »
Hi
I had Mach4 running under XP pro SP3  I did a fresh install of XP on the same computer  with XP pro SP3
I tried mach4  4.2 3233  and get error "could not initialize the core"
I tried Mach4  4.2 3804  and get error  "could not initialize the core RC=-17"
I am at a loss to know what to try it had worked the new copy of XP seems to be running perfectly apart from Mach4 not starting
any idea's
Regards Ray
Re: XP PRO SP3 Mach4 will not RUN
« Reply #1 on: November 05, 2018, 07:33:51 PM »
Hi
any idea's
Regards Ray
https://www.machsupport.com/forum/index.php?topic=31441.0 I know this was a previous topic about this problem but I cant find or search for it the search function is not working
« Reply #2 on: November 05, 2018, 10:12:39 PM »
Well I spent a hour or 2 and searched manually the forum for a post I knew had to be there and found the answer
Net.framework needs to be installed on the computer I installed that and we are all good
« Last Edit: November 05, 2018, 10:14:16 PM by Raymondo »
