Hello Guest it is October 22, 2026, 09:35:37 PM
Author Topic: g83.1 question  (Read 7941 times)
g83.1 question
« on: October 27, 2018, 06:47:34 PM »
downloaded build 3804 and used my lathe screen set and then the default lathe screen set.
Wanted to make sure that a peck drilling cycle was going to work the way I wanted so I copied the code from the lathe manual and ran it in the simulator.
G0 G54 G19 G40 G80
t0202
G97 S2500 M3
G0 Z0
g0x0
G83.1 G99.1  x0.0 Z-1.5 R.2 Q0.125 F2
G80
M30
Attached is a picture of the result.  It always goes to x 0.400 at the end and doesn't run as described in the manual.  What am I  missing.  Does this run the same in other builds?
TIA
RT
Re: g83.1 question
« Reply #1 on: October 28, 2018, 02:03:02 PM »
Solved
Re: g83.1 question
« Reply #2 on: October 28, 2018, 02:22:03 PM »
rhtuttle.
How was this solved so we can all know?
Chad Byrd
Re: g83.1 question
« Reply #3 on: October 28, 2018, 02:24:59 PM »
I didn't read the full explanation of the example.  I need g17 to drill from the Z plane.  the example drills from the x plane
