Hello Guest it is October 22, 2026, 10:29:28 PM
Author Topic: Run Script on startup  (Read 6055 times)
« on: October 26, 2018, 11:07:04 AM »
Hello, me again.
I'm in the process of upgrading from mach3 to mach4, and as I have many scripts in VB, I need to redo everything for Lua.
At this point I am still understanding the Lua syntax, and define how I am going to do this upgrade with the least possible effort.
So,
I created a script just for outgoing tests / inputs, messaging etc, and I recorded it with the name outputCheck.mcs on the macro folder, so far so good.
the strange thing is, every time I start mach4 this script runs once, if you turn off the mach 4 and start again the script run agains one time.
What's the secret, who knows?
Re: Run Script on startup
« Reply #1 on: October 26, 2018, 04:23:37 PM »
I think mach runs through every macro on startup to make sure there are no errors in your macros.
Chad Byrd
