Hello Guest it is October 22, 2026, 11:08:14 PM
Author Topic: Lua append txt file  (Read 5889 times)
Lua append txt file
« on: October 25, 2018, 12:16:56 PM »
Hello,
I try append on txt file, and there is a problem, if the file dont exist, this script create a file and write the message.
but if the file already exist, the File return a nil values, and dont append the message
File = io.open("C:/perfLogs/Log1.txt", "a+" )
File:write("test...")
File:close()
Is this code supposed to work for append mode? Why does not it work?
Any one?
Re: Lua append txt file
« Reply #1 on: October 26, 2018, 10:56:34 AM »
Solve,
The folder as to be maximum share permition.
it's a little weird because if the file does not exist the script creates a new one, but for some reason if it already exists, it's not possible to append.
Any way, solve.
