Hello Guest it is November 13, 2026, 01:29:52 PM
Author Topic: invisible gremlins  (Read 23383 times)
  •  9,377 9,377
Re: invisible gremlins
« Reply #10 on: October 27, 2018, 03:32:04 AM »
Assuming I have the correct .xml...
As ZASto has said your accelerations are too high.
I think you need to make many changes to your setup but just make one at a time, saving the change, restarting Mach then checking the result.
I suggest...
1) Set your X an Y axis Velocity to 2000 and Acceleration to 200.
2) Z acceleration to 90
You have a conflict of Pins where you have Enable1 set as Port 1 Pin 14 and also X Axis Direction Pin as Port 1 Pin 14 - this needs correcting.
You have M3 set for Output#6 which is not enabled or set to any Port or Pin.
There are many other things that need attention but just try those to start with.
« Reply #11 on: October 27, 2018, 03:46:31 AM »
Thank you Tweakie.CNC,
I will make the corrections and let you know how it goes, I think I've stared at it all so much i can't see the wood for the trees now so a fresh pair of eyes is needed, i would be interested in the other changes that are needed as we go. I still have to configure the mpg (Wireless) and also see if i can get the spindle running through mach 3, i am using an RS485 adapter to the vfd. I disconnected it and have been switching it on at the vfd which seems to run with no interference to the steppers. When i run it through mach 3 it "jitters".
Thank you for the help and as i said i will let you know how it goes.
Regards
Tackleboxman
Offline ZASto
  •  434 434
« Reply #12 on: October 27, 2018, 10:27:38 AM »
OK, I "messed" a bit with your xml, slightly modified you can find here: https://cloud.mail.ru/public/Ge8H/kygbcU1Q9
My personality is who I am.
« Reply #13 on: October 27, 2018, 10:41:29 AM »
Wow ZASto,
Thank you very much, i will definitely try it out and report back here. I appreciate the help very much. Thank you.
Offline ZASto
  •  434 434
« Reply #14 on: October 27, 2018, 01:34:58 PM »
You're welcome.
« Reply #15 on: October 29, 2018, 01:31:22 AM »
Hi Zasto,
Just tried the new xml file with the better settings for accel and velocity and still the machine is jerky. Do you have any other ideas for me.  ???
« Reply #16 on: October 29, 2018, 01:40:50 AM »
I also have a new gremlin... When I load the g code it all load into the g code window but only a small section loads into the table display window.
« Reply #17 on: October 29, 2018, 02:53:30 AM »
OK, I went into config, ports and pins, spindle setup and unchecked "use spindle motor output" and the jerking went away. It seems that problem is there somewhere. And I've just noticed I'm running in demo mode hence the limited lines. Just added my license and all good. I can run the spindle manually for now and the machine is running smoothly. Gonna try some code. Smiley face, smiley face.
Offline ZASto
  •  434 434
« Reply #18 on: October 29, 2018, 02:57:27 AM »
Well, it depends on your job size.
Your table is set to be 2350mm x 1320mm.
Mach usually displays the whole table defined in Confing->Homing/Limits (you have Soft limits enabled si Mach "knows" size of your table).
On second image it is visible the size of the job ~263 x 338 :)
A bit more tweaked xml: https://cloud.mail.ru/public/5Xbx/3sCDS1hq5
« Last Edit: October 29, 2018, 03:07:23 AM by ZASto »
