Hello Guest it is November 13, 2026, 01:54:19 PM
Author Topic: Mach3 turn stops after 150 lines  (Read 24887 times)
« on: October 20, 2018, 06:13:28 AM »
I use Mach3 mill for 2 years and I am really happy with it.
So now my CNC lathe is ready to work, but I have a big problem and I dont´t know why.
I use windows xp 32bit with sp3  paraleport and Mach3 turn R3.043.066.
If I load the program code into Mach3, it stops always at line 150.
My pc in my living room has windows 7 ultimate 64bit and I always test the programm there and look at the preview window.
So the program runs perfectly to the end.
Booth Pc has the same settings and they aren´t in the demo mode.
I would be very grateful if you can help me.
Regards racer2012
« Last Edit: October 20, 2018, 06:15:46 AM by racer2012 »
  •  9,377 9,377
Re: Mach3 turn stops after 150 lines
« Reply #1 on: October 20, 2018, 06:36:34 AM »
If I load the program code into Mach3 stops always at line 150.
Do you have any message in the status bar when your Gcode stops at line 150 ??
Could be a problem with your Gcode - one install of Mach3 accepts it the other does not. Probably the most common cause of one PC accepting Code and another not is the IJ settings being different between the two PC's. Perhaps check this (Config. / General Config.).
There are known issues with Mach3 version .066 so I suggest that you download and install version R3.043.062 http://www.machsupport.com/software/downloads-updates/
It can be installed over the top of your existing version without loosing your settings but always make a secure backup of your existing Mach3 folder (just in case).
Hope this helps,
« Reply #2 on: October 20, 2018, 06:49:34 AM »
Thank you for your help.
No messages in staus, it stops like program ending.
I have mach3  reinstalled, have the program run in demo mode and it stops again at line 150th.
Could it be that my license is not recognized, although it is displayed to me at "help"-> about mach3 control.
I will install version R3.043.062 and give you a feedback.
Regards racer2012
  •  9,377 9,377
« Reply #3 on: October 20, 2018, 06:56:31 AM »
It is not a license issue - In Mach3 Turn the unlicensed limit is 50 lines of Gcode.
Do you have any message in the Status bar / window when it stops at line 150 ?
« Reply #4 on: October 20, 2018, 07:31:37 AM »
So I install R3.043.062, I start mach3 turn in demo modus and it stoped again at line 150.
Then I put the licence into the mach3 folder and the problem persits.
There are no messages when it stop at line 150.
Here is my g code.
Code: [Select]
G21
(TOOL - 1 OFFSET - 1)
(DREHSTAHL 1  INSERT - NONE)
T101
G97 S1500 M03
G0 G54 X104. Z1.25
Z0.
G99 G1 X17.2 F200.
G0 Z2.
X97.605
Z4.5
G1 Z-16.8
X107.571
G0 Z4.5
X93.639
G1 Z-16.8
X104.005
G0 Z4.5
X89.674
G1 Z-16.8
X100.039
G0 Z4.5
X85.708
G1 Z-16.8
X96.074
G0 Z4.5
X81.742
G1 Z-16.8
X92.108
G0 Z4.5
X77.776
G1 Z-16.8
X88.142
G0 Z4.5
X73.81
G1 Z-16.8
X84.176
G0 Z4.5
X69.844
G1 Z-16.8
X80.21
G0 Z4.5
X65.878
G1 Z-16.8
X76.244
G0 Z4.5
X61.912
G1 Z-16.8
X72.278
G0 Z4.5
X57.946
G1 Z-16.747
G2 X60.804 Z-16.82 I1.429 K13.906
X62.312 Z-16.8 K13.979
G1 X68.312
G0 Z4.5
X53.98
G1 Z-16.122
G2 X57.461 Z-16.727 I2.589 K4.634
G1 X58.346 Z-16.763
X64.346
G0 Z4.5
X50.014
G1 Z-14.207
X50.898 Z-14.85
G2 X53.922 Z-16.108 I4.167 K3.468
G1 X54.38 Z-16.211
X60.38
G0 Z3.792
X42.513
G1 Z1.792
X48.049 Z-.976
G3 X48.4 Z-1.4 I-.424 K-.424
G1 Z-11.376
Z-11.385
G2 X49.783 Z-14.039 I5.437
G1 X50.414 Z-14.498
X56.414
G0 Z1.954
X45.907
G1 Z-.046 F150.
X47.907 Z-1.046
G3 X48.2 Z-1.4 I-.353 K-.353
G1 Z-11.38
Z-11.387
G2 X59.226 Z-16.9 I5.513
G1 X59.241
X96.2
X101.571
X104.4 Z-15.486
G0 Z1.883
X45.766
G1 Z-.117
X47.766 Z-1.117
G3 X48. Z-1.4 I-.283 K-.283
G1 Z-11.384
Z-11.388
G2 X59.224 Z-17. I5.612
G1 X59.232
X96.2
X101.571
X104.4 Z-15.586
G0 Z1.25
G28 U0. W0. M05
T100
M01
(TOOL - 2 OFFSET - 2)
(DREHSTAHL 77  INSERT - NONE)
T202
G97 S1000 M03
G0 G54 X19.933 Z4.7
G1 Z-31.261 F180.
X18.
X15.172 Z-29.847
G0 Z4.7
X21.866
G1 Z-31.261
X19.533
X16.705 Z-29.847
G0 Z4.7
X23.799
G1 Z-31.261
X21.466
X18.638 Z-29.847
G0 Z4.7
X25.732
G1 Z-31.261
X23.399
X20.571 Z-29.847
G0 Z4.7
X27.665
G1 Z-31.261
X25.332
X22.504 Z-29.847
G0 Z4.7
X29.598
G1 Z-31.261
X27.265
X24.437 Z-29.847
G0 Z4.7
X31.531
G1 Z-3.906
[color=red]X30.662 Z-5.21
G2 X30.6 Z-5.4 I.569 K-.19[/color] Stops here.
G1 Z-6.4
Z-31.261
X29.198
X26.37 Z-29.847
G0 Z4.7
X33.464
G1 Z-2.291
X32.04 Z-3.24
G2 X31.862 Z-3.41 I.48 K-.36
G1 X31.131 Z-4.506
X28.303 Z-3.092
G0 Z4.7
X35.397
G1 Z-1.002
X33.064 Z-2.557
X30.236 Z-1.143
G0 Z4.7
X37.33
G1 Z-.347
X36.063 Z-.663
G2 X35.64 Z-.84 I.268 K-.536
G1 X34.997 Z-1.268
X32.169 Z.146
G0 Z4.7
X39.263
G1 Z.137
X36.93 Z-.447
X34.102 Z.968
G0 Z2.047
X39.353
G1 Z.047 F100.
X36.153 Z-.753
G2 X35.8 Z-.9 I.224 K-.447
G1 X32.2 Z-3.3
G2 X32.051 Z-3.442 I.4 K-.3
G1 X30.851 Z-5.242
G2 X30.8 Z-5.4 I.475 K-.158
G1 Z-6.4
Z-31.461
X27.972 Z-30.047
G0 Z1.958
X39.442
G1 Z-.042
X36.242 Z-.842
G2 X35.96 Z-.96 I.179 K-.358
G1 X32.36 Z-3.36
G2 X32.241 Z-3.474 I.32 K-.24
G1 X31.041 Z-5.274
G2 X31. Z-5.4 I.38 K-.127
G1 Z-6.4
Z-31.461
X28.172 Z-30.047
G0 Z1.25
G28 U0. W0. M05
T200
M30
At my pc in my living room, it runs perfect to the end.
Regards racer2012
  •  9,377 9,377
« Reply #5 on: October 20, 2018, 09:54:52 AM »
I just tried your Gcode (simulation on my PC) and after removing your stop comments it ran all 200 lines just fine.
I am out of ideas on this one.
Perhaps one of the Turn experts has come across this problem before and knows the answer.
« Reply #6 on: October 20, 2018, 02:55:52 PM »
so the error still exists.
I have Mach3 turn R3.043.062 installed on a PC of a friend, only in demo mode.
Mach3 has never been installed on the PC, the Pc has Win7 Ultimate.
We try my posted Gcode with the demo mode and it runs perfectly to the end.
Next we try to test mach3 on another pc with win xp 32 bit.
« Reply #7 on: October 20, 2018, 10:20:45 PM »
So I tested a other Win XP 32bit Pc, exactly the same problem.
It always stopped at line 150, with or without a license.
In summary, at two different Win 7 ultimate Pc's it runs perfectly to the end, with and  without license and at two different Win XP 32bit Pc's it always stopped at line 150 with and without license.
Mach 3 should stop in the demo version after 50 lines of code, but I continue to line 150.
My guess is that I have a problem with the license. maybe you have more ideas and solutions.
Regards racer2012
  •  9,377 9,377
« Reply #8 on: October 21, 2018, 12:50:30 AM »
In simulation mode or without the driver installed Mach3 Turn will run without any line limitation with or without a license file installed. It is only when the driver has been installed that the 50 line limit applies.
« Reply #9 on: October 21, 2018, 04:34:41 AM »
hi,
at the other 3 Pc's there was no hardware connected, because it is a bit more difficult to get to the electronics of the machine. It was tested in each case in the simulation and as if I were starting a real program, the result is at Win7 that it runs to the end and at XP stops after 150 lines, just like at the machine.
The problem with Win 7 ultimate 64 bit is that it does not support the paarallelport
