Hello Guest it is October 24, 2026, 02:51:42 PM
Author Topic: ERROR - 30 when tryin to load cut file to Mach4 made in Fusion 360  (Read 8236 times)
Can anyone help me? I'm getting an (error - 30 while loading file K:\5X8SPOILTSLOT.nc) when opening G-Code file in Mach4. It was made in Fusion 360. See attached picture.
Re: ERROR - 30 when tryin to load cut file to Mach4 made in Fusion 360
« Reply #1 on: October 19, 2018, 10:50:31 PM »
I use Fusion 360 posts all the time in Mach4 and have never had this error message pop up.
You are using the Artsoft Mach4 post processor?
Post your code file on here so it can be tested by other users to duplicate the problem.
Chad Byrd
« Reply #2 on: October 20, 2018, 01:09:06 AM »
Are you using the MACH4Mill post processor?  It should be generating a .tab NC extension.  You can find the MACH4MILL post in the Autodesk HSM post library. https://cam.autodesk.com/hsmposts?
- Robert Beaubien
- Drone Plastics
“Dear Algebra, Please stop asking us to find your X.  She's never coming back and don't ask Y.”
« Reply #3 on: October 20, 2018, 07:27:43 AM »
I'm using Arcsoft Mach4 post processor. Here's the GCode, please let me know if it looks good.
(1001)
(DESKTOP36X70)
(T1  D=1. CR=0. - ZMIN=-0.125 - FACE MILL)
G90 G94 G91.1 G40 G49 G17
G20
G28 G91 Z0.
G90
(FACE2)
M5
M9
T1 M6
S3600 M3
G54
G0 A0. C0.
M9
G0 X72.05 Y0.457
G43 Z1.4375 H1
G18 G3 X70.55 Z-0.0625 I-1.5 K0. F39.4
G1 X70.
X0.
G17 G2 Y1.4046 I0. J0.4738
G1 X70.
G3 Y2.3521 I0. J0.4738
G1 X0.
G2 Y3.2996 I0. J0.4738
G1 X70.
G3 Y4.2471 I0. J0.4738
G1 X0.
G2 Y5.1947 I0. J0.4738
G1 X70.
G3 Y6.1422 I0. J0.4738
G1 X0.
G2 Y7.0897 I0. J0.4738
G1 X70.
G3 Y8.0372 I0. J0.4738
G1 X0.
G2 Y8.9848 I0. J0.4738
G1 X70.
G3 Y9.9323 I0. J0.4738
G1 X0.
G2 Y10.8798 I0. J0.4738
G1 X70.
G3 Y11.8273 I0. J0.4738
G1 X0.
G2 Y12.7749 I0. J0.4738
G1 X70.
G3 Y13.7224 I0. J0.4738
G1 X0.
G2 Y14.6699 I0. J0.4738
G1 X70.
G3 Y15.6174 I0. J0.4738
G1 X0.
G2 Y16.565 I0. J0.4738
G1 X70.
G3 Y17.5125 I0. J0.4738
G1 X0.
G2 Y18.46 I0. J0.4738
G1 X70.
G3 Y19.4076 I0. J0.4738
G1 X0.
G2 Y20.3551 I0. J0.4738
G1 X70.
G3 Y21.3026 I0. J0.4738
G1 X0.
G2 Y22.2501 I0. J0.4738
G1 X70.
G3 Y23.1977 I0. J0.4738
G1 X0.
G2 Y24.1452 I0. J0.4738
G1 X70.
G3 Y25.0927 I0. J0.4738
G1 X0.
G2 Y26.0402 I0. J0.4738
G1 X70.
G3 Y26.9878 I0. J0.4738
G1 X0.
G2 Y27.9353 I0. J0.4738
G1 X70.
G3 Y28.8828 I0. J0.4738
G1 X0.
G2 Y29.8303 I0. J0.4738
G1 X70.
G3 Y30.7779 I0. J0.4738
G1 X0.
G2 Y31.7254 I0. J0.4738
G1 X70.
G3 Y32.6729 I0. J0.4738
G1 X0.
G2 Y33.6204 I0. J0.4738
G1 X70.
G3 Y34.568 I0. J0.4738
G1 X0.
G2 Y35.5155 I0. J0.4738
G1 X70.
G18 G2 X71.5 Z1.4375 I0. K1.5
G0 X72.05 Y0.457
Z1.375
G3 X70.55 Z-0.125 I-1.5 K0. F39.4
G1 X70.
X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G1 X0.
G1 X70.
G18 G2 X71.5 Z1.375 I0. K1.5
G17
M9
G28 G91 Z0.
G90
G28 G91 X0. Y0.
G90
M30
« Reply #4 on: October 20, 2018, 09:20:56 AM »
I copied your code to notepad and saved it as .nc
When I opened the code in Mach4 it said there was an error:      Axis 5 commanded while disabledE-Stop cleared!
C Axis is commanded.
I enabled the B and C Axis in Mach config and re generated the program and it generated with no errors.
Chad Byrd
Offline smurph
  •  1,575 1,575
« Reply #5 on: October 21, 2018, 01:49:05 PM »
-30 is MERROR_NOT_COMPILED.  This means that there is a macro with a syntax error that could not compile.  The system tries to compile all of the macros that have changed since the last compile when the control is reset.  Loading a file does an implicit reset on the control.
Steve
