Hello Guest it is November 13, 2026, 12:26:27 PM
Author Topic: VB Script  (Read 37919 times)
Offline TPS
  •  2,627 2,627
Re: VB Script
« Reply #10 on: October 07, 2018, 09:28:32 AM »
ok try this, sorry i can't test the code for the Moment.
Code: [Select]
'simple X-center script
Sub Main()
SetOEMDro(800,0)
    'do the X- probe
    Message ("probe X- ")
    Code "G31 X-100 F150"
    While IsMoving()
        x = GetOEMDRO(800) 'X actpos
        If x <= -100 Then
            DoOEMButton(1003) 'Stop too far no probe hit
            MsgBox ("Probe X- canceled , no probe hit!" )
            Exit Sub
        End If
    Wend
'get the exact probepos
ProbeXNeg = GetVar(2000)
'clear the probe
Code "G91 X2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
    'do the X+ probe
    Message ("probe X+ ")
    Code "G31 X200 F150"
    While IsMoving()
        If x >= 200 Then
            MsgBox ("Probe X+ canceled , no probe hit!" )
            Exit Sub
        End If
    Wend
ProbeXPos = GetVar(2000)
'goto the center
middle = ProbeXNeg + ((ProbeXPos - ProbeXNeg)/2)
Code "G90 G01 Y" + CStr(middle)
SetOEMDro(800,0)
End Sub
Re: VB Script
« Reply #11 on: October 07, 2018, 11:57:12 AM »
That's a Mach3 internal message that the probe input is active when the probe move is called.
Make sure your probe is wired and working properly. Look at the LED on the diagnostics page. The LED should be off, and come on when the probe is triggered.
Everything is good with the probe Gerry, it works great on all other probing routines.
Re: VB Script
« Reply #12 on: October 07, 2018, 12:01:17 PM »
Code: [Select]
Sub Main()
SetOEMDro(800,0)
    'do the X- probe
    While IsMoving()
        If x <= -100 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
    'do the X+ probe
    While IsMoving()
        If x >= 200 Then
            Exit Sub
        End If
    Wend
'goto the center
SetOEMDro(800,0)
End Sub
We are certainly getting closer my friend, It now probes X- no problem, touches off, then starts to go X+, as soon as it touches the X+ I get the warning again.
Sorry for being a pain in the a** guys.
Offline TPS
  •  2,627 2,627
Re: VB Script
« Reply #13 on: October 07, 2018, 12:47:10 PM »
no idea why this warning Comes up, but try this code:
Code: [Select]
Sub Main()
SetOEMDro(800,0)
    'do the X- probe
    While IsMoving()
        If x <= -100 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
    'do the X+ probe
    While IsMoving()
        If x >= 200 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X-2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
'goto the center
SetOEMDro(800,0)
End Sub
Re: VB Script
« Reply #14 on: October 07, 2018, 02:26:46 PM »
Code: [Select]
Sub Main()
SetOEMDro(800,0)
    'do the X- probe
    While IsMoving()
        If x <= -100 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
    'do the X+ probe
    While IsMoving()
        If x >= 200 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X-2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
'goto the center
SetOEMDro(800,0)
End Sub
Ok buddy, this is what I am getting now.
Start probing routine and the first move is X-  After touching off on X- , it starts to go X+ , and after touching off, it now retracts 2mm, and the X dro now updates to read 0.000
I am completely baffled by all this.
Offline TPS
  •  2,627 2,627
Re: VB Script
« Reply #15 on: October 08, 2018, 12:00:03 AM »
Code: [Select]
Sub Main()
SetOEMDro(800,0)
    'do the X- probe
    While IsMoving()
        If x <= -100 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
    'do the X+ probe
    While IsMoving()
        If x >= 200 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X-2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
'goto the center
    While IsMoving()
Sleep(10)
    Wend
SetOEMDro(800,0)
End Sub
Re: VB Script
« Reply #16 on: October 08, 2018, 02:35:43 AM »
Code: [Select]
Sub Main()
SetOEMDro(800,0)
    'do the X- probe
    While IsMoving()
        If x <= -100 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
    'do the X+ probe
    While IsMoving()
        If x >= 200 Then
            Exit Sub
        End If
    Wend
'clear the probe
Code "G91 X-2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
'goto the center
    While IsMoving()
Sleep(10)
    Wend
SetOEMDro(800,0)
End Sub
Still the same I'm afraid ! On one attempt it done the X- no problem and then when it touched off on X+ it backed off 2mm, moved Y+ 2mm and the dro then updated to X 0.000  Y2.000
Re: VB Script
« Reply #17 on: October 08, 2018, 05:55:46 AM »
Are you using a parallel port, or a motion controller? Many motion controllers don't work properly with the GetVAR commands. Especially the Chinese controllers.
Re: VB Script
« Reply #18 on: October 08, 2018, 07:49:14 AM »
I'm using a genuine UC300 USB controller, and as I said before, every other probing routine works perfectly, in both Mach3 and UCCNC, it's just this "finding the centre in X" move that's got me beat !
Offline TPS
  •  2,627 2,627
Re: VB Script
« Reply #19 on: October 09, 2018, 04:21:32 PM »
ok was a "Little bit" ofline, added some debuging msg boxes, to see what is going on
Code: [Select]
Sub Main()
SetOEMDro(800,0)
    'do the X- probe
    While IsMoving()
        If x <= -100 Then
            Exit Sub
        End If
    Wend
MsgBox "X Probe - : " + CStr(ProbeXNeg)
'clear the probe
Code "G91 X2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
    'do the X+ probe
    While IsMoving()
        If x >= 200 Then
            Exit Sub
        End If
    Wend
MsgBox "X Probe + : " + CStr(ProbeXPos)
'clear the probe
Code "G91 X-2 F150"
    While IsMoving()
Sleep(10)
    Wend
Code "G90"
'goto the center
MsgBox "center : " + CStr(middle)
Code "G90 G01 X" + CStr(middle)
    While IsMoving()
Sleep(10)
    Wend
SetOEMDro(800,0)
End Sub
