Hello Guest it is November 13, 2026, 03:56:46 PM
Author Topic: Auto Z zero  (Read 20890 times)
  •  9,377 9,377
Re: Auto Z zero
« Reply #10 on: October 07, 2018, 02:46:28 AM »
The version I am running is R3.042.037.
Is the a more resent version if so were do I down load it and do I have to pay?
Hi Mike,
You can download the most recent version of Mach3, (completely free of charge  :) ) from here;  http://www.machsupport.com/software/downloads-updates/
and Yes it will run on XP or Win7.
Re: Auto Z zero
« Reply #11 on: October 07, 2018, 05:48:09 AM »
Many thanks
Mike
Re: Auto Z zero
« Reply #12 on: October 07, 2018, 07:02:04 AM »
The screenset should work fine on that version.
Your Mach3 license is good for all versions of Mach3. The latest version is here, but I actually use an older version than you are using (I think 3.042.020 or .029)
http://www.machsupport.com/wp-content/uploads/2013/04/Mach3Version3.043.exe
If you are using the parallel port, you'll need a 32 bit version of Windows 7.
I have a spare computer with nothing on it excepted windows XP I down loaded my Mach3 but when I put the 2010 screen set in I don't get full graphics.
What do you mean by "full graphics". If backgrounds are missing, the screenset is installed in the wrong place.
Re-installing **should** fix it, IF there's a problem. but I can't guarantee that it will, or that it won't make it worse.
Re: Auto Z zero
« Reply #13 on: October 08, 2018, 10:02:54 AM »
Where should the screenset be installed?
Mike
Re: Auto Z zero
« Reply #14 on: October 08, 2018, 10:40:35 AM »
Wherever your Mach3 folder is. It's sometimes easy to install it in Mach3\Mach3\ if you don't pay attention during the install.
You should have a Mach3\bitmaps\2010\ folder. If you don't, the graphics won't be displayed.
Re: Auto Z zero
« Reply #15 on: October 09, 2018, 02:28:07 AM »
Thank you, the computer in the workshop went bust yesterday when I tried to install the updated Mach3, as I thought some thing is corrupt on the drive, So I am stating again with a new/old computer.
Mike
