Hello Guest it is November 24, 2026, 01:08:00 AM
Author Topic: Mach 4+ Darwin LPT- motor doesn´t work  (Read 7553 times)
« on: September 30, 2018, 07:08:47 AM »
Hi CNC maniacs.  Two days ago i transfer CNC to mach 4 because i hate linux (working good but win is win :-). Install mach 4, install Darwin and pay darwin. If i setting darwin i look to learning video. But motors doesn´t work.  Input Output Home XYZ emergency Stop etc function but motors ,,dead,. If i turn off PC motor function ( i dont turn with finger) if i turn ON PC motor dead and if i have enable in mach 4 motor doesnt start. Have you same problem?  Input and output pins i must setting on darwin and in mach 4 control. But motor pins i can setting only in Darwin. I do everything what i see in Tutorial video but mission failed.
 Sorry for my english i am czech.
CNC components ( LPT controll desk http://www.cncshop.cz/cnc-io-board_c), driver 3ND883, leashine stepper 863S42
thanks for answer
in the near future I would like to buy ESS
Offline thosj
  •  542 542
Re: Mach 4+ Darwin LPT- motor doesn´t work
« Reply #1 on: October 01, 2018, 06:45:12 AM »
I don't know anything about Darwin other than it needs to run on a 32 bit install of Windows. If Windows is 64 bit, no go.
Tom
« Reply #2 on: October 01, 2018, 08:34:13 AM »
Did you try changing the Active Low setting for your steps pins? That is a pretty common cause for motor troubles.
-Bryanna
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
« Reply #3 on: October 01, 2018, 09:57:22 AM »
 win 7 32
i didn´t changing this setting. i try  Active low. tomorrow i try.
« Reply #4 on: October 04, 2018, 06:01:17 AM »
my mistake. i forget pin 17 enable motor
