Hello Guest it is November 13, 2026, 08:07:05 PM
Author Topic: Macro in G-code pauses execution for 1 sec  (Read 8758 times)
« on: September 27, 2018, 01:26:28 AM »
Hello,
I have a problem with executing macros. Everything runs smoothly except when the code needs to run macro, for example M29, which just disables movement on axis A, it pauses just for 1 second and after that it continues normally.
I am using Mach3, Hicon integra board and Leadshine drivers.
I would like it to run without this 1 second pause. Where does the problem lies. What do I need to fix. Thank yiu for your answers.
« Last Edit: September 27, 2018, 01:28:40 AM by Foger »
Offline TPS
  •  2,627 2,627
Re: Macro in G-code pauses execution for 1 sec
« Reply #1 on: September 27, 2018, 01:43:42 PM »
if you Show us your M29 macro, somebody will be able to help you.
« Reply #2 on: September 27, 2018, 03:05:20 PM »
I just gave example. Macro M29 can even be empty with 0 code in it and when G-code reaches the point to call macro it waits for about 1 second and then continue normaly. I would just like to see CNC work with some constant speed without stops.
I found out that the problem probably lies in Hicon Integra  board, because i tried and run the same code on other CNC which has a board from leafboy77 and the code runed smoothly without any stops when it hit the macro.
Maybe I should change some settings for Hicon board to run macros more smooth?
Offline TPS
  •  2,627 2,627
« Reply #3 on: September 28, 2018, 01:03:36 AM »
or contact vital Systems customer Support?
