Hello Guest it is November 13, 2026, 08:00:29 PM
Author Topic: Slow Zones not working using soft limits (no homing switches fitted)  (Read 7792 times)
Hello.  My Machine (Chinese) CNCest 6040 no limit switches fitted. RnR Motion USB card.
After many lost hours I've just about sorted my Mach 3 setup and have everything running as expected.
Only issue is the slow zones don't work. I've tried a number of settings.
From what I can tell the USB card support slow zones.
I've not Enabled the Axis input signals in Ports and pins (as I'm only using soft limits).
All other ports and pins are set as per the user guide for my machine and appear to be working as expected.
Can anyone help?
Re: Slow Zones not working using soft limits (no homing switches fitted)
« Reply #1 on: September 25, 2018, 01:56:48 PM »
I suspect the RnR USB card does not support that feature.
The only people who would know are those who make it but good luck trying to find and contact them.
