Hello Guest it is November 01, 2026, 12:43:05 PM
Author Topic: Edit Button Script Window MIA  (Read 10662 times)
Offline Duael
  •  14 14
  • Artist
    • Robert Stein III
« on: September 15, 2018, 12:41:16 PM »
Hello,
New to Mach3
I opened the Operator > Edit Button Script yesterday, just to look at it for the possibility of editing later if needed, then closed it.
Today I clicked on the drop down menu Operator > Edit Button Script, and while parts of the User Interface started flashing (as is apparently normal) the window itself was not visible.
It is also not moved off screen, as Winbloz is apt to do on occation. (as far as I can tell, I'm a Mac guy and here I am using Winbloz7 32bit)
Meanwhile, the VB Script Editor does open on screen.
Any ideas as how I might find my Lost Script Window would be appreciated.
Thank you
Re: Edit Button Script Window MIA
« Reply #1 on: September 15, 2018, 01:14:47 PM »
Did you click on a button after choosing "Edit Button Script"?
Offline Duael
  •  14 14
  • Artist
    • Robert Stein III
« Reply #2 on: September 15, 2018, 01:30:40 PM »
ger21,
Do you mean a button in the main User Interface window, or the Close/exit/whatever button on the Edit Button Script Screen?
As I recall, I opened the Edit Button window, looked it over while talking to my machine maker on the phone,  and then closed by clicking the X at upper Right.
« Reply #3 on: September 15, 2018, 01:40:37 PM »
When you use Operator>Edit Button Script, you have to click on one of the blinking screen buttons before the actual editor will open.
Offline Duael
  •  14 14
  • Artist
    • Robert Stein III
« Reply #4 on: September 15, 2018, 05:26:39 PM »
Thank you
