Hello Guest it is November 28, 2026, 01:09:52 AM
Author Topic: cutting a spiral  (Read 17527 times)
cutting a spiral
« on: September 14, 2018, 10:02:34 PM »
I'm trying to mill a spiral. anyone know the code? I found a G2.1 code but Mach3 doesn't like it.
Chuck
Re: cutting a spiral
« Reply #1 on: September 14, 2018, 11:07:35 PM »
codes G2 and G3 are circular arc/helical interpolation moves.
See for instance 'CNC Programming Handbook' by Peter Smid, its pretty much the Gcode bible.
They are fixed radius, you cannot to my knowledge use them as a spiral.
The way to do it is use CAD to draw the part including the spiral toolpath then use CAM to generate the Gcode.
« Reply #2 on: September 15, 2018, 06:59:00 AM »
In Mach3, you can cheat with G2/G3 to create a spiral, by specifying the end of the arc to be offset from where it should be.
Load this code into Mach3 and you'll see a spiral.
G40 G90
G91.1
S10000 M3
G0 Z0.1250
G0 X0.0000 Y-0.7400 Z0.1250
G1 X0.0000 Y0.1233 Z-0.1000 F75
G2 X0.0000 Y0.1233 Z-0.1000 I0.0000 J-0.1233 F100
G2 X0.0000 Y0.2467 Z-0.1000 I0.00 J-0.1233
G2 X0.0000 Y0.3700 Z-0.1000 I0.00 J-0.2467
G2 X0.0000 Y0.4933 Z-0.1000 I0.00 J-0.3700
G2 X0.0000 Y0.6167 Z-0.1000 I0.00 J-0.4933
G2 X0.0000 Y0.7400 Z-0.1000 I0.00 J-0.6167
G2 X0.0000 Y0.7400 Z-0.1000 I0.00 J-0.7400
G0 Z0.1250
G0 X0.0000 Y0.7500 Z0.1250
G1 X0.0000 Y0.7500 Z0.0000 F75
G2 X0.0000 Y0.7500 Z-0.1000 I0.0000 J-0.7500 F100
M30
« Reply #3 on: September 16, 2018, 01:17:09 PM »
 Thanks  Gerry,
That’s what I’m looking for I will give it a try.
Chuck
« Reply #4 on: September 17, 2018, 10:09:52 AM »
Worked great!!!
Did you do this manually or is there a program to create the code?
Chuck
« Reply #5 on: September 17, 2018, 10:25:09 AM »
I use this AutoCAD macro that I wrote. It creates these "spirals" when pocketing circles.
http://www.thecncwoodworker.com/ac2gc.html
« Reply #6 on: September 17, 2018, 10:49:13 AM »
 Nice, I use solideorks.
 Maybe I can find a macro for it.
« Reply #7 on: September 17, 2018, 02:22:02 PM »
 As it turns out Brian wrote a wizard for cutting spirals in Mach3
Chuck
« Reply #8 on: September 17, 2018, 05:13:01 PM »
Forgot all about that.
« Reply #9 on: September 18, 2018, 12:02:29 PM »
CamBam does spirals too. I cut flange faces to mate to round tanks. I project the spiral onto a surface with the tank radius and spiral inwards from the outside edge. Very efficient tool path.
