Hello Guest it is November 12, 2026, 01:57:47 AM
Author Topic: Mach4: API "Gcode File" syntax error  (Read 14555 times)
« on: September 10, 2018, 04:11:58 AM »
Hi everyone,
I'm writing script in Mach4 to read a Gcode line for calculation, but function mcCntlGetGcodeLine, mcCntlGetGcodeLineCount appears "syntax error" when I compile, I tried to change the syntax but error still apear, Please help me fix this error, thank you.
My code:
       inst = mc.mcGetInstance()
       local int LineNumber = 5 --line number need to read
       local char Gcodeline[128]
Syntax No1:  mc.mcCntlGetGcodeLine(inst, LineNumber, Gcodeline, 128) --Get line number 5 from the Gocde file loaded into controller
or Syntax No2:   Gcodeline = mc.mcCntlGetGcodeLine(inst, LineNumber)
Re: Mach4: API "Gcode File" syntax error
« Reply #1 on: September 10, 2018, 06:05:50 AM »
just a guess but Lua is not type declared.....try removing the 'int' and 'char' from you variable definitions.
« Reply #2 on: September 10, 2018, 06:59:21 AM »
Thank you Mr. Craig, there is no error now, the correct code is:
       local LineNumber = 5
       local Gcodeline
       mc.mcCntlGetGcodeLine(inst, LineNumber, Gcodeline, 128) --Get line number 5 of the Gocde file loaded.
or:   Gcodeline = mc.mcCntlGetGcodeLine(inst, LineNumber)--Get line number 5 of the Gocde file loaded.
