Hello Guest it is November 01, 2026, 12:42:28 PM
Author Topic: LazyCam Manual  (Read 24398 times)
LazyCam Manual
« on: July 30, 2007, 04:40:36 PM »
where I find the handbook or the help of lazycam 2,05 ?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: LazyCam Manual
« Reply #1 on: July 30, 2007, 09:05:57 PM »
Hi, Bul@bul.it
LazyCam is so lazy and still in Bata-Ver., Watch the videos above in tutorials "Video's".
Lots of changes planed, No time to write a manual now.
Load-up a Dxf file, It's not bad at all, A little buggy hear and there.
Just give it a try, Chip
Re: LazyCam Manual
« Reply #2 on: November 16, 2007, 12:03:50 PM »
How do I "Move to origin upon completion" which used to be an option on the Gcode save menu ? It seems to have disappeared. I use plasma mode.
Offline Chip
  •  2,055 2,055
Re: LazyCam Manual
« Reply #3 on: November 16, 2007, 06:43:41 PM »
Hi, Alex718
Edit your G-code file, Put a M30 at the end.
M30
Hope this Helps, Chip
Re: LazyCam Manual
« Reply #4 on: November 17, 2007, 09:26:17 AM »
I have another problem with LazyCam and or Mach3 plasma. When I create the gcode, I need the program to delay to wait for the torch to come on before moving the head. In Lazycam I put in 2 seconds wait and the gcode comes out G4 P2.0000. Problem is this looks like something much smaller than 2 seconds as the head starts to move before the 2 sec would be up. I put in 1000 and the program does wait for 1 second. What is wrong ? I have to go into the gcode and manually change all the P values to make this work.
Offline Chip
  •  2,055 2,055
Re: LazyCam Manual
« Reply #5 on: November 17, 2007, 03:39:01 PM »
Hi, Alex718
There's a setting in Mach3 under Config, General Confgi, Right side "G04 Dwell in ms" make sure it's not Checked.
Also in Config, Ports & Pins, Spindle Setup, General Parameters, "CW Delay Spin Up", That May give you a default delay.
Re: LazyCam Manual
« Reply #6 on: November 17, 2007, 07:21:29 PM »
Chip, thanks for the help. The G4 dwell in milliseconds was checked, I guess it is a default setting. I am sure this will fix my problem
Thanks again
Offline Vogavt
  •  260 260
Re: LazyCam Manual
« Reply #7 on: August 20, 2008, 11:16:57 PM »
Any update on when a manual for LazyCam will be available? I watched the two videos, but they're a little outdated.
Vogavt
Offline Chip
  •  2,055 2,055
Re: LazyCam Manual
« Reply #8 on: August 21, 2008, 12:03:10 AM »
Hi, Vogavt
LazyCam is still in Bata version, Not likely to have manuat, un-till it's worked on more.
Chip
Offline Vogavt
  •  260 260
Re: LazyCam Manual
« Reply #9 on: August 21, 2008, 08:13:29 AM »
Yeah, I know it's beta, but since there's a "Pro" version out how much "worked on more" is needed before something hit's the streets?   ;D
I'd think those that have paid for the "Pro" version would at least have a later, more updated video of how the new features are supposed to work.
And "No", I'm not complaining so please don't take it as such. Just asking questions!   ;D
Vogavt
