Hello Guest it is November 13, 2026, 10:01:05 AM
Author Topic: Help with Position of Home and Piece Part  (Read 21967 times)
« on: March 26, 2006, 01:44:31 PM »
Please see attached doc for explanation of what I strive to do. I've read and reread the manual and watched the videos and I still can't seem to grasp it. :'( :'( :'( Also when I run G code from V Carve the machine runs it up in the air. The moves seem to be OK but, all it cuts is air and the Z axis movements are backwards. HELP!!!!!!!
« Last Edit: March 26, 2006, 04:47:30 PM by stringkilla »
Re: Help with Position of Home and Piece Part
« Reply #1 on: March 27, 2006, 05:50:34 AM »
Okay I think I am starting to see where your problem is... If you press Page Down is the spindle going down? are the numbers gettng more negitive?
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: March 27, 2006, 05:16:17 PM »
Brian have you looked at my query attachment. I think this may have a lot to do with my ongoing problems. Take a look at it and see if you can tell me in plain English how to work it out. As I said I've watched the video on co'ord's and homing and find it very confusing for some reason.  I'm ready to throw this whole business int the toilet ;D ;D and get on to another very expensive hobby. LOL I'm insane, :-[ :-[
« Reply #3 on: March 27, 2006, 06:20:43 PM »
Can you post it as a jpeg... I can't read that other file.
www.machsupport.com
Offline Bloy
  •  158 158
« Reply #4 on: March 28, 2006, 12:26:57 AM »
Hi Brian,
  Open that file with "wordpad" and it will show a graphic and a paragraph of what Stringkilla is trying to do.
     I wish I could help on this....
..or open this PDF file...
« Last Edit: March 28, 2006, 12:41:12 AM by Bloy »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #5 on: March 28, 2006, 02:57:42 AM »
You could use a setting jig something like the picture.
Make the jig from 1/4" alum plate and bolt it to the machine table anywhere, then clock it square to the axis.
The 1/2" hole is a setting hole so you can clock it at the start and set X and Y zero at this point.
Then have G54 set at -12" and -6"
The 3 off 1/4" dia pins then locate the work in the correct place.
The drawing is in metric by the way.
Graham.
« Reply #6 on: March 28, 2006, 04:15:08 PM »
Graham.
  Thanks I think a fixture like that will work, as soon as I find out how to set my part Zero. Thanks for the idea.
