Hello Guest it is November 13, 2026, 10:33:58 AM
Author Topic: Auto tool height setter macro for auto tool changer - to set the lot of them  (Read 7940 times)
First, I used search (unsuccessfully) to see if I could find if someone has done this before.  I have a CNC router running Mach3.  67x66x11 inch x,y,z.   It has a 15 position rack type tool changer at one edge that holds ISO 20 tools for its 3HP atc spindle.  So I have a tool change macro for it that seems to work.  I also have a tool height setter at one end of the tool rack.  Has anyone already written a macro to auto set all of the tools in the rack?
Offline TPS
  •  2,627 2,627
create am macro, lets say M1000.M1s
code of the probemacro can be something like this:
Code: [Select]
Sub Main()
'get Parameter ------------------------------------------------------
Tool = Param1()
'ceck toolnumber----------------------------------------
If ((Tool < 1) or (Tool > 16)) then
    Message ("toolnumber not valid")
    GoTo Ende
End If
    'load the tool
    Code "M6 T" + cstr(Tool) + " M5"
' PUT HERE SOME CODE TO DRIVE TO THE PROPBEPOSITIO
    'do the probing
ZM_in = 100 'max probing distance
    Code "G31 Z100" + CStr(ZM_In) +"F50"
    While IsMoving()
        z = GetOEMDRO(802) 'act Z-pos
        If z <= ZM_In Then
            DoOEMButton(1003) 'Stop if too far
            MsgBox ("probe not hit" )
            GoTo Ende
        End If
    Wend
    'et the probepos
    ZProbePos = GetVar(2002)
    'put the value into tooltable
    SetToolParam(Tool,2, ZProbePos)
    'save tooltable
    DoOEMButton(316)
' PUT HERE SOME CODE TO COME OUT OF THE PROBEPOS
    'unload the tool
    Code "M6 T0"
Exit Sub
Ende:
    Code "M30"
    'Message ("error while probing")
End Sub
then you can do a probing with
M1000 P1 to probe tool 1 or
M1000 P2 to probe tool 2
the P-Parameter is the toolnumber.
now you can create a smal G-code file, where you can call M1000 for all your Tools.
be Patient, the posted code is not tested and not complete, it is just to give you an idea.
