Hello Guest it is September 27, 2026, 02:35:38 PM
Author Topic: Coordinates don’t change  (Read 17796 times)
« on: August 26, 2018, 07:15:14 AM »
I have 8nstalled Mach3 on a Toshiba laptop running Windpws7. Install went smoothly but I can’t change coordinates. Using the tab function, I cannot advance the numbers in X Y or Z.  The midi control does seem to work, but at a ver6 slow speed. Suggestions?
Thank you,
Jim Widmann
Re: Coordinates don’t change
« Reply #1 on: August 27, 2018, 05:03:45 AM »
Hi Jim
do you have any motors enabled in Config/Ports and Pins/ Motor Outputs?.
If you don't have a motor enabled the DRO will not change. Don't worry you can enable a motor but not hook it up,
Mach doesn't know that, and it can't tell, its not a feedback system.
When you first turn Mach on the federate is set very low. Try MDIing:
F100     and then try a few MDI instructions.
« Reply #2 on: August 27, 2018, 05:50:00 AM »
Thanks Craig,
I do have the motors enabled. Still no movement on the DRO. Also I set the feed rate to f100 and the DRO still moved very slowly: about .03 per second.
Any other ideas on this?
Jim
« Reply #3 on: August 27, 2018, 05:57:14 AM »
are you using a parallel port or an external controller?
« Reply #4 on: August 27, 2018, 06:55:32 AM »
I’m using the parallel port. I have two computers that work ok using the parallel port, and two that I use smooth stepper on. But in either case the dro moves.
« Reply #5 on: August 27, 2018, 02:09:00 PM »
laptops are notorious for not running parallel ports well. Although I would still expect the DRO's to work.
Could it be the laptop is just plain faulty. Do you have any other software you could run on it as a comparison?
« Reply #6 on: August 27, 2018, 06:20:51 PM »
Craig,
Yeah, I know laptops are kind of a hit or miss proposition when using the parallel port. But I have had luck with two of them, and my current project sort of requires a portable computer.
Yes, I was able to run a similar motion control software. It’s very weird that the DRO doesn’t move. I have re-installed it twice and that didn’t work.
Should I just forget it?
« Reply #7 on: August 27, 2018, 06:24:48 PM »
I've run out of ideas......I didn't have that many to start with :D
Mach3 does run on laptops but maybe just not your one?
« Reply #8 on: August 27, 2018, 07:02:36 PM »
Run Drivertest exe, and post the results.
Disregard any mention of System Excellent.
What you are looking for is a steady pulse rate that's close to the kernel speed. If the Kernel Speed is 25Khz, you should see a pulse rate close to 25000.
« Reply #9 on: August 27, 2018, 09:07:03 PM »
Ok I ran drivertest and here are the results:
On the graph the time between pulses seems to be about 55
CPU MHZ 1496
Shortest time. 57.659
Long3st time   3345.98
Version:  6.1
PCI 1 second low.  3579545
PCI 1 second HI.   1496000000
Average.     152.83
Longest.        105133.0
“Pulsing too fast”
I’m gonna guess I should set the kernel speed to someth8ng like 60.
Thank you!
Jim
