Hello Guest it is September 27, 2026, 05:09:54 PM
Author Topic: cant confirm the wizard window and cant close it  (Read 8532 times)
« on: August 24, 2018, 01:11:34 AM »
hi ,please see the atach window ,when i try run the Cv wizard its open the window ,but as you see i cant cinfirm cant close ..
thanks
Re: cant confirm the wizard window and cant close it
« Reply #1 on: August 24, 2018, 09:04:06 AM »
Good morning,
This has to do with your settings in Windows. You may need to play around a bit with your resolution/scaling settings. If you are using scaling to "zoom in" that can cause part of the wizard window to be cut off, as you're seeing.
-Bryanna
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
« Reply #2 on: August 24, 2018, 09:37:41 AM »
hi
i test change resulotion ,and not help
its only on the CV tuning wizard(the most important) and i think only last dounload ,because previus pc i didnt have sach problem
« Reply #3 on: August 24, 2018, 09:49:55 AM »
What is your scaling set to? I had another user in the past with this issue (Win10 computer) and they had to adjust their scaling in order to see the entire wizard window. You can search 'scaling' or look in the Display settings.
-Bryanna
« Reply #4 on: August 24, 2018, 10:09:55 AM »
hi ,i try all options from 1920*1080(recomened) up to 1366*768
also try all size from 1005 up to 175%
nothig help
and again its only with one wizard screen (which is the only i need) all the rest show well
« Reply #5 on: August 24, 2018, 10:18:49 AM »
Let's try something new then. Open up the Script Editor, go into the Wizards folder, and find mcCvTuningWizard.mcs. Open that and find the UI information (starts around line 132). You can change the values in wx.wxSize ( , ) to make the wizard window larger. You may also need to change the wx.wxSize( , ) in the line below as well. Give that a try and let me know if it allows you to see and use the buttons at the bottom.
Thank you,
Bryanna
« Reply #6 on: August 24, 2018, 10:41:32 AM »
thanks alot
