Hello
Guest
it is
October 21, 2026, 08:53:33 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Continuous jog mode
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Continuous jog mode (Read 12268 times)
horizon_gp
Continuous jog mode
on:
July 28, 2007, 02:35:07 AM »
I am able to Step Jog but cannot activate Continuous Jog. Slow Jog Rate set at 100%. Lights for Continuous/Step Jog toggle as expected. Cycle Jog Step set to 1.0000
Any ideas ?
Re: Continuous jog mode
Reply #1 on:
July 28, 2007, 03:52:55 PM »
can you post your xml and I will see if I can find anything.
Brian Barker
3,860
Reply #2 on:
July 29, 2007, 02:49:16 PM »
Will it work if you press and hold the Shift Key and press the arrow key?
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
horizon_gp
Reply #3 on:
July 30, 2007, 04:37:57 AM »
Problem solved. Reading through some related blogs, I tried varying my motor velocity. At lower speed continuous jog works fine. I must have been exceeding the capacity of the motors to respond.
Thanks for your willingness to help.
Print
Pages:
1
Go Up
« previous
next »
