Hello Guest it is November 13, 2026, 03:12:14 PM
Author Topic: Problems with ver. ...062 on WinXP  (Read 15584 times)
« on: August 06, 2018, 08:34:01 PM »
When i try to load a g-code with a half-sphere on winXP machines, the image comes out like this and the machining toolpath acts in the same way. It goes longer in -x direction than in the other directions. What may be wrong?
  •  9,377 9,377
Re: Problems with ver. ...062 on WinXP
« Reply #1 on: August 07, 2018, 12:22:22 AM »
Looks like it is a problem with your generated Gcode.
If you attach your Gcode file it can be checked.
« Reply #2 on: August 07, 2018, 06:59:21 AM »
No. It´s nothing wrong with the g-code. It works properly on a win-7 installation I have on another PC. Here is the G-code:
G01 X0 Y0 Z27,5 F30
G01 X1,1813 Y0 Z27,4785 F30
G03 X1,1813 Y0 I-1,1813 J0 F30
G01 X2,361 Y0 Z27,4141 F30
G03 X2,361 Y0 I-2,361 J0 F30
G01 X3,5376 Y0 Z27,3069 F30
G03 X3,5376 Y0 I-3,5376 J0 F30
G01 X4,7095 Y0 Z27,157 F30
G03 X4,7095 Y0 I-4,7095 J0 F30
G01 X5,8752 Y0 Z26,9645 F30
G03 X5,8752 Y0 I-5,8752 J0 F30
G01 X7,0332 Y0 Z26,7299 F30
G03 X7,0332 Y0 I-7,0332 J0 F30
G01 X8,1818 Y0 Z26,4533 F30
G03 X8,1818 Y0 I-8,1818 J0 F30
G01 X9,3197 Y0 Z26,1351 F30
G03 X9,3197 Y0 I-9,3197 J0 F30
G01 X10,4452 Y0 Z25,7758 F30
G03 X10,4452 Y0 I-10,4452 J0 F30
G01 X11,5569 Y0 Z25,3758 F30
G03 X11,5569 Y0 I-11,5569 J0 F30
G01 X12,6533 Y0 Z24,9357 F30
G03 X12,6533 Y0 I-12,6533 J0 F30
G01 X13,733 Y0 Z24,456 F30
G03 X13,733 Y0 I-13,733 J0 F30
G01 X14,7946 Y0 Z23,9373 F30
G03 X14,7946 Y0 I-14,7946 J0 F30
G01 X15,8366 Y0 Z23,3805 F30
G03 X15,8366 Y0 I-15,8366 J0 F30
G01 X16,8577 Y0 Z22,7861 F30
G03 X16,8577 Y0 I-16,8577 J0 F30
G01 X17,8565 Y0 Z22,155 F30
G03 X17,8565 Y0 I-17,8565 J0 F30
G01 X18,8317 Y0 Z21,488 F30
G03 X18,8317 Y0 I-18,8317 J0 F30
G01 X19,782 Y0 Z20,7861 F30
G03 X19,782 Y0 I-19,782 J0 F30
G01 X20,7062 Y0 Z20,05 F30
G03 X20,7062 Y0 I-20,7062 J0 F30
G01 X21,603 Y0 Z19,2808 F30
G03 X21,603 Y0 I-21,603 J0 F30
G01 X22,4713 Y0 Z18,4796 F30
G03 X22,4713 Y0 I-22,4713 J0 F30
G01 X23,3099 Y0 Z17,6473 F30
G03 X23,3099 Y0 I-23,3099 J0 F30
G01 X24,1176 Y0 Z16,7851 F30
G03 X24,1176 Y0 I-24,1176 J0 F30
G01 X24,8935 Y0 Z15,8941 F30
G03 X24,8935 Y0 I-24,8935 J0 F30
G01 X25,6365 Y0 Z14,9755 F30
G03 X25,6365 Y0 I-25,6365 J0 F30
G01 X26,3456 Y0 Z14,0304 F30
G03 X26,3456 Y0 I-26,3456 J0 F30
G01 X27,0199 Y0 Z13,0603 F30
G03 X27,0199 Y0 I-27,0199 J0 F30
G01 X27,6585 Y0 Z12,0662 F30
G03 X27,6585 Y0 I-27,6585 J0 F30
G01 X28,2605 Y0 Z11,0497 F30
G03 X28,2605 Y0 I-28,2605 J0 F30
G01 X28,8252 Y0 Z10,0119 F30
G03 X28,8252 Y0 I-28,8252 J0 F30
G01 X29,3518 Y0 Z8,9542 F30
G03 X29,3518 Y0 I-29,3518 J0 F30
G01 X29,8396 Y0 Z7,8781 F30
G03 X29,8396 Y0 I-29,8396 J0 F30
G01 X30,288 Y0 Z6,7851 F30
G03 X30,288 Y0 I-30,288 J0 F30
G01 X30,6963 Y0 Z5,6764 F30
G03 X30,6963 Y0 I-30,6963 J0 F30
G01 X31,0641 Y0 Z4,5536 F30
G03 X31,0641 Y0 I-31,0641 J0 F30
G01 X31,3908 Y0 Z3,4182 F30
G03 X31,3908 Y0 I-31,3908 J0 F30
G01 X31,6761 Y0 Z2,2717 F30
G03 X31,6761 Y0 I-31,6761 J0 F30
G01 X31,9194 Y0 Z1,1155 F30
G03 X31,9194 Y0 I-31,9194 J0 F30
G01 X32,1206 Y0 Z-0,0487 F30
G03 X32,1206 Y0 I-32,1206 J0 F30
G01 X32,2794 Y0 Z-1,2195 F30
G03 X32,2794 Y0 I-32,2794 J0 F30
G01 X32,3954 Y0 Z-2,3952 F30
G03 X32,3954 Y0 I-32,3954 J0 F30
G01 X32,4687 Y0 Z-3,5744 F30
G03 X32,4687 Y0 I-32,4687 J0 F30
G01 X32,4991 Y0 Z-4,7555 F30
G03 X32,4991 Y0 I-32,4991 J0 F30
G01 X32,5 Y0 Z-5 F30
G03 X32,5 Y0 I-32,5 J0 F30
« Reply #3 on: August 07, 2018, 07:31:20 AM »
So you say. ;)
The attached file shows the pathing. Notice that the pathing is NOT based on the center of the sphere.
« Reply #4 on: August 07, 2018, 07:51:46 AM »
So you say. ;)
Did you get the same result on your machine with this g-code? What is then wrong with the code and why does it work properly on my win-7 installation?
« Reply #5 on: August 07, 2018, 07:59:38 AM »
Here is the image from my win-7 PC. I have no cnc-mill connected to this PC, so I haven´t tried to make a sphere with it, but when I run the program offline, the x an y movements are at the same level. There is not an incremental -x value then.
« Last Edit: August 07, 2018, 08:08:34 AM by jaru-eri »
« Reply #6 on: August 07, 2018, 12:05:52 PM »
Your IJ Mode is wrong, put a G91.1 on a line of its own at the start of the code and it will look fine.
It can also be changed in General Config but I personally prefer to have it in my G Code as that will ensure it is correct no matter which mode Mach is in at the time of loading the code.
« Reply #7 on: August 07, 2018, 04:26:40 PM »
Thankyou very much Hood! You solved this problem for me..
Do you think I need this line also in codes which I generate in Vectric´s V-carve? If so, are there any ways to add this line automatically every time I create new codes with that program?
« Reply #8 on: August 07, 2018, 04:59:02 PM »
The backplot of the gcode was for absolute IJ mode which is my default mode of operation. Should have mentioned that in my reply.
« Reply #9 on: August 08, 2018, 06:18:27 AM »
You should be able to edit the post processor in Vectric to put the G91.1 in. If you are not sure how to do that then the other option is to change the default in Mach. As said though code can change the IJ mode so I prefer to have it in the code itself as you always know even if Mach is defaulted to the opposite the code will still run correctly.
The setting is on the General Config page (from Config menu)
