Hello
Guest
it is
November 13, 2026, 06:03:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
mach4 and cambam ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach4 and cambam ? (Read 7767 times)
gorf23
190
mach4 and cambam ?
on:
August 06, 2018, 09:19:58 AM »
I have a gcode file I created with cambam and seem to have an problem with g83 and the Q word the code has many lines with g83 but only the first g83 line has the Q the rest don't
so mach4 it showing an error at the next g83 line no Q word.. it works ok with mach3 just not mach4 any suggestions?.
Thanks gary
Cbyrdtopper
985
Re: mach4 and cambam ?
Reply #1 on:
August 06, 2018, 09:26:09 AM »
There has been a post about this very issue before.
http://www.machsupport.com/forum/index.php/topic,33845.0.html
Mach4 only requires G83 on the first line of the canned cycle and it probably requires a Q since that is the peck depth variable.
Last Edit: August 06, 2018, 09:28:59 AM by Cbyrdtopper
Chad Byrd
gorf23
190
Reply #2 on:
August 06, 2018, 11:33:12 AM »
thanks that worked.
I did a search before I posted but that message didn't pop up sorry..
Gary
Cbyrdtopper
985
Reply #3 on:
August 06, 2018, 11:34:48 AM »
No worries,
It should have popped up with the G83 search, but didn't. I kind of knew what I was looking for though and was able to find it pretty quickly.
Glad you got it figured out!
Chad Byrd
Print
Pages:
1
Go Up
« previous
next »
