Hello Guest it is October 21, 2026, 03:47:24 AM
Author Topic: AMD 64X2 3200 DUAL CORE  (Read 35752 times)
Re: AMD 64X2 3200 DUAL CORE
« Reply #10 on: July 25, 2007, 01:23:35 PM »
RMD,
    What do you have your debounce set at in general config?
Offline RMD
  •  13 13
« Reply #11 on: July 25, 2007, 02:02:57 PM »
The debounce is 100.
RMD
RMD
« Reply #12 on: July 25, 2007, 02:23:25 PM »
Try setting it to 2000 and see if it helps. Do you have the PC hooked into a network in any way?
Offline RMD
  •  13 13
« Reply #13 on: July 25, 2007, 03:13:15 PM »
Tried 2000 debounce did not work, no the CPU is stand alone or dedicated, not even seen the first day on the Internet also.
RMD
RMD
« Reply #14 on: July 25, 2007, 03:45:28 PM »
How does the drivertest look? Does the Graph spike in any way? Is the cpu speed constant? Any fluctuation in puls speed?
What is your enery profile set to?
I just ran the driver thert on this laptop that I am writing this on and I can assure you that after I saw the graph it made I will never connect it to anything that moves. Unless large black squares can be seen as a good thing.
vmax549
« Reply #15 on: July 25, 2007, 06:22:41 PM »
Doesn't really sound like a computer hardware problem, sounds like an interupt problem caused by a process that comes and goes. Let the driver test run for a while and watch for something that interupts the stream. Possible something trying to update itself or a house cleaning process
The fact that the other putor works ok rules out something downstream of the putor
Offline RMD
  •  13 13
« Reply #16 on: July 25, 2007, 06:26:30 PM »
David
The drivertest is as follows: Time between pulses  about 38  with a clean line
                                       Pulses per sec:   23881-23760 90% of the time at 23881
                                       Cpu speed:  2004
RMD
RMD
vmax549
« Reply #17 on: July 26, 2007, 08:31:59 AM »
Does the problem just randomly occur or have you kept track of time and it occures in about the same length of time each time?
Please describe the problem again in detail.
Offline RMD
  •  13 13
« Reply #18 on: July 26, 2007, 10:21:33 AM »
    Just got the fix, a Dell senior case manager just called and after an hour on the phone Dell is going to send  me
    a new computer with an Intel processor.
   Thanks to everybody for there input. I know the fix does not fix the problem but it does for me.
   RMD
RMD
vmax549
« Reply #19 on: July 26, 2007, 04:58:32 PM »
RMD let us know how it turns out. If it is a program running in the background it may show up with the new putor also. I had to chase several of those demons when I first got started. (;-) TP
Is that the treasure island over by Eustis? (;-)
