Hello Guest it is October 25, 2026, 10:51:03 AM
Author Topic: Radius to end of arc differs from-  (Read 9781 times)
« on: July 19, 2018, 12:51:42 PM »
I have used my home built CNC router for some time now free of any major problems or errors. However yesterday I was running a project that I created in Fusion 360, and when I loaded the G-code into my Mach3 software. I received an error informing me that the Radius to end of arc differs from- not able to read the remainder.
After repeatedly running the G-code of a simple circle and coming up with the same error, I now ran the model and g-Code through Cam Bam and yet I received the very same error. Am I correct assuming that the problem is in Mach 3 and if so any ideas on how to repair the problem.
Thank You for any help anyone can provide.
Jim
Re: Radius to end of arc differs from-
« Reply #1 on: July 19, 2018, 03:03:58 PM »
Check your IJ mode in General Config. In most cases, it should be set to incremental.
« Reply #2 on: July 19, 2018, 03:46:18 PM »
ger21
Thank you very much for your help with my problem. You hit the nail on the proverbially head with your suggestion, all is well. By the way, I’m also a licensed user of your screen set which I use exclusively.
Gerry Thank you once again for your help
Jim
