Hello Guest it is November 13, 2026, 05:46:05 PM
Author Topic: work zero in mach 4  (Read 51175 times)
Offline Stuart
  •  311 311
Re: work zero in mach 4
« Reply #30 on: August 03, 2018, 10:11:53 AM »
I think that reverse check box him no worky at least on mine with a ESS it don’t just change the step dir from active low to high or high to low in other words if it low make it high if it’s high make it low
That needs fixing before you go any further else bad things will happen when you run gcode
Ref all
Use MDI to tell Mach what tool you are using eg T1 M6
WCS. To put it in its most basic least accurate way put a tool in the spindle jog over until the center of the cutter is over the corner of your work and nearly touching the work ,then zero XYZ. DRO’s now you have the WCS set and the tool length set . For that job only
« Reply #31 on: August 03, 2018, 10:22:15 AM »
Hey Stuart,
Depending on the motion controller the Reverse Checkbox will change it.
I've had to do just as you, change the high to low in the Plugin Config for an ESS here at work, but on the HiCON Integra, I just have to check this checkbox I am referring to.
Personally, I think the Mach Configure Checkbox should be the Reverse Override and not the plugin pin output, it should communicate that information over to the motion controller.
Chad Byrd
« Reply #32 on: August 03, 2018, 12:46:19 PM »
ok this is my screenshot link. Tell me what your ideas are LOL. Kind of going Gooffy
Ken
https://mail.google.com/mail/ca/u/0/?ui=2&ik=a19f226350&view=att&th=16500e380b1f3e3a&attid=0.1&disp=safe&zwcc
Offline Stuart
  •  311 311
« Reply #33 on: August 03, 2018, 12:52:13 PM »
Don’t want to join google mail
« Reply #34 on: August 03, 2018, 12:56:27 PM »
I have gmail and can't open that.  Can you just attach a .jpg?
Chad Byrd
« Reply #35 on: August 03, 2018, 12:57:51 PM »
Not real sure how to do it. I will swing the bat and see what happens
« Reply #36 on: August 03, 2018, 01:28:10 PM »
OK try this
https://mail.google.com/mail/ca/u/0/?ui=2&ik=a19f226350&view=att&th=165010a89d9ee276&attid=0.1&disp=safe&realattid=f_jkeblkj00&zwKen
« Reply #37 on: August 03, 2018, 02:18:07 PM »
Hi Ken,
when you are posting just to the left and below the text input pane there is a 'Additional Options' link.
When you are ready to attach a picture or diagram or whatever hit that.
Note that the attached file will have to have a unique name, the website will not accept a file with an indentical name.
Also if you are attaching photos please preprocess them on your PC so they are about 500kB. Many people post pics which are so big
you have to scan around to see it all and often still miss the critical detail that was the purpose of the pic in the first place.
« Reply #38 on: August 03, 2018, 03:27:36 PM »
OK , i had no idea that this screen was even here. All i have been doing is from the quick response at the bottom of the post page. I read your message and looked all over and found nothing for options. I thought well if i wasn;t the dummy before i am now if i have to post that i can't find it. I started to respond and clicked preview and bang i found it.
ken,
 LOL my wife thinks i am nuts, she herd me say o---------t out loud
let me know if the ayyachment is there
Still laughing errer occured
« Reply #39 on: August 03, 2018, 03:29:51 PM »
I don't know how to preprocess
ken
